Checked these values for Splangy, thought I'd post it up in a thread since I didn't see it in our old conversations. I believe this applies to all the early 25 and 40 clusters.
I did a few readings on a working stock sender so we could have a record of the values, unfortunately it wasn't too cool today (74*) but it doesn't matter much to the gauge.
So here's a picture of a stock sending unit on a 25.
And here's the setup, to read the resistance you must disconnect the wire to the gauge. The yellow wire taped to the adapter pipe is a thermocouple to read the temperature.
OK, cold temp (gauge buried left) is 74*, resistance is 43 ohms. To read the resistance you must remove the wire to the gauge and read between the terminal and body of the sender.
