Temp Sender for Early Cluster.
Higganum.
Checked these values for Splangy, thought I'd post it up in a thread since I didn't see it in our old conversations. I believe this applies to all the early 25 and 40 clusters.
I did a few readings on a working stock sender so we could have a record of the values, unfortunately it wasn't too cool today (74*) but it doesn't matter much to the gauge.
So here's a picture of a stock sending unit on a 25.
And here's the setup, to read the resistance you must disconnect the wire to the gauge. The yellow wire taped to the adapter pipe is a thermocouple to read the temperature.
OK, cold temp (gauge buried left) is 74*, resistance is 43 ohms. To read the resistance you must remove the wire to the gauge and read between the terminal and body of the sender.
151* and 24.4 ohms NOTE once you are in working range, there will be very little change in resistance................
For laughs I tried a temp sender that I had marked as 1970.........70* at 160 ohms and 200* at 65 ohms...............so with the old cluster it should basically go to cold on the gauge and stay there, which is what it did, and is why I've got this new temp sender on the shelf...........
