Nuts. I got to figure out how to get my doors to shut better.
Boy Ryan is right on that one. The bolts that secure the upper hinges are difficult to get at and from the factory the hinges are sealed. Doable, like anything but not easily. I'd hate to see that nice paint on your 40 get marred adjusting the hinges.Has anyone adjusted the body side of the door hinges? I think if I can push those outward the rear of my doors will come in.
Just slam the doors harder.Nuts. I got to figure out how to get my doors to shut better.
You usually don't have to is the centering tool, if the shims we're kept in the correct places throughout its life.I'm with you on that Jeff. I think this is the last winter I'll use my hard top. Probably sell it once spring comes around and get some soft doors and a soft top.
One side is leaking, other side is not.You usually don't have to is the centering tool, if the shims we're kept in the correct places throughout its life.
I finally got around to testing the gear mesh pattern. The marking paint didn't really rub off where I painted it on the ring but the transfer from the ring to the pinion back to the ring seems ok to my untrained eye.
Were you worried about the pattern to begin with? If it were a well used 3rd, I would imagine that the ring gear would have the pattern pretty well represented without having to paint it... I'd be looking at the spider gears for rounding and feathering...I painted the ring. Here's where I painted it. It's pretty faint but there's a little pattern there. I had to spin it a bunch of times to get it to show this much.
