SOLD Tan 1985 Fj60 Landcruiser
tan-13-jpg.2850139
This Is my latest project Late 1985 FJ60 project (Miles 240K on body.) STOCK 60
I own several of these trucks/parts for them and bought this truck to bring it back to life. As the motor was blown up when I originally bought it. Over the years of owning many of these 60s this is by far the nicest Land Cruisers I have owned. It’s drives tight and exceptionally smooth. This is 100% a turnkey driver that you could drive daily or heck drive cross country tomorrow if you wanted to.
Here is some videos links of the truck build and story-
(Motor swap)
(Fixing and details)
(Finished and driving)
FORSALE: Finding a Late 1985 Toyota FJ60 Land Cruiser In Empty Back Storage Lot: PT6 - FINISH LINE! - https://www.youtube.com/watch?v=5UDZoKMJ-P0
New parts- (everything replaced with in the last 20 miles)
-Installed healthy low miles used 2F motor
-New Clutch & Pressure plate
-Flywheel resurfaced
-New Throw-out bearing & Pilot bearing.
-Hastings Fuel Filer
-Newer battery hold down
-New Battery
-Newer 31-inch Goodyear All Terrain Mud Tires
-Fresh Oil & radiator fluid
-New front marker lights- installed and fixed
-All new spark plugs, wires, rotor, cap
-Bought original early style factory center console and brought back to life
-Fresh transmission gear oil
-Ac Charged and working
-New Pass head light bulb
- Original Toyota Carb added and tuned
-Newer hoses throw out engine & gas tank
-New sending unit
-Fixed huge rip on Drivers side seat and welded seat bracket to give its strength back
-radio and speakers reinstalled
-Upgraded to Champion Aluminum radiator
-Brake booster and Master replaced
-Replaced both dome lights
-New wiper blades
-Replaced wiper blade arm bezels on Cawl
-Front light bezels, Front Toyota Emblem and grilled replaced. All reanchored correctly
-Added Correct Battery Tray
-Factory Hood Liner Added
-Factory Toyota center caps added for both front and rear rims
-Newer Power steering pump
-New Fan Clutch
-Replace glove box door
-Replaced dash Ash tray drawer
-New Valve Cover Gasket
PROS-
-AC WORKS!
-1 spot of rust
-The frame is perfect. The best frame I’ve seen in this area by far. (Which I coated with rust inhibitor to further its life)
-4 Speed Manuel
-4wd & manual locking hubs
-Front driver’s seat has no rip
-Knuckles are in excellent shape and not leaking
-Tape deck and original speakers (Use a Tape deck with cord to play music off iPhone)
-Turn key truck
-Truck paint was buffed and waxed. As I believe the PO had this truck painted at some point. Which really made the paint pop.
- Register it with antique plates & Only pay for tags once
-Entire interior/carpet pulled and cleaned
-Sought after Tan paint and period correct 80s stripping.
-Degreased entire engine bay when motor was installed
-All lights on truck were tested and are working order
-Newer Goodyear 31-inch all terrain mud tires
-Desmogged bullet proof 6 cylinder 2f Engine
-Correct Toyota 2f carb added and tuned.
CONS-
-Crack in windshield
- Small area of rust on driver’s door jam.
Let me know what other questions I can answer for you
Looking to get 30,000K Will consider offers
I have a ton of cruiser parts as well so welcome to drop me a line if you’re just looking for something.
Still available? Contact me on PM, I have a trade option you might be interested in.
View attachment 2850133View attachment 2850136View attachment 2850137View attachment 2850138
tan-13-jpg.2850139
(Motor swap)
-New Battery
-New sending unit
-New wiper blades
-New Fan Clutch
PROS-
-AC WORKS!
-1 spot of rust
-4 Speed Manuel
-Turn key truck
CONS-
are you running the truck with the engine like that?
you're sucking in unfiltered air into the engine.
