Tampa - St Pete area get together
Holy crap! Did I just count 18 trucks?!?
I don't even know if we had that good of a turnout for Turkey Trot!!!!
a special thanks to Trace, our professional photographer.
Here's a link to the pictures he took:
http://www.photosbytrace.com/Cars/20130416-Land-Cruiser-Meet/28957352_sg3fwt#!i=2461759377&k=h956N6g
Is there a build thread on that mini truck?
Not a great build thread as it was multiple threads over time. But here is a list of whats in it when it changed hands.
~Nov. 1982 Toyota Hilux
~2004 Toyota Tacoma 2RZ with 34,900 miles on the clock (includes title from Tacoma motor)
~Marlin Crawler HD 1200 Clutch and Flywheel
~Toyota Fiberglass Bed(Full, Double wall, From Toyota Fiberglass in BC, New body Bushings and Stainless Steel Hardware
~Tacoma A/C, New TOYOTA Condenser, New A/C Dryer, A/C Dye Injected in case of leak
~80 Series Land Cruiser Master Cylinder
~KenWood Speakers, Controlled by amplifier/I-Phone/I-Pod Hook Up
~Optima Red Top
~2001 Toyota 4Runner 16" Aluminum Wheels
~BFG-KM1 255/85 R16 (33.1)
~Warn M8000 with AmSteel Blue Synthetic Rope, Controls mounted in Engine Bay
~30 Spline Chromoly Longfield Axles
~Chromoly Longfield Hub Gears
~Marlin Crawler HD inner axle seal
~80series High Pinion E-Locker
~12 Volt Guy E-Locker Switches
~W56-E 5 Speed Transmission
~Marlin Crawler Dual Ultimate Crawler Box (Built by Marlin) 2.28/4.7 W/Synthetic gear oil
~Marlin Crawler VSS
~Tom Woods Drive Shaft
~Tacoma Rear axle
~Tacoma E-locker 4.11
~Marlin Crawler U-Bolt/ Spring Plates
~Tacoma Rear springs w/ added leafs, MC zinc Plated Shackles
~Fully boxed and Sealed Frame with 3/16 Steel, Lengthened MC spring hangers
~Marlin Crawler Rear Bumper
~DOM .120 Sliders
~Bud Built T-Case Crossmember/ Slider
~.188 DOM Front Drive Shaft
~New TOYOTA Rear Wheel Cylinders, Pads, Drums and Hardware
~Braided Steel Brake Lines
~Toyota Land Cruiser Front Disc Brakes
~4Runner Calipers, TOYOTA Brake pads
~Tacoma Gauges
~All New TOYOTA lens(Turn Signal, Front and Rear Markers)
~Early Style Grill,Buckets and Lights
~Early Style Steering Wheel
~Hella H4 7" Glass Headlights
~High Clearance Front bumper
~New TOYOTA Denso Heated Air/Fuel Sensor
~Mobil 1 Fully Synthetic 5w-30 changed every 4-5K
~Toyota Red Coolant, Stainless Steel Over Flow Tank
~New Radiator Barn Radiator
~Tacoma Gas Pedal
~New Toyota Belts, Hoses
~6 Bolt Engine Mount ( No more torn rubber engine mounts)
~Newer EFI Gas tank and Fuel Pump
~Stainless Steel Fasteners Thru 95% of the Vehicle, New Zinc Plated Fasteners in Structural Locations
~ New Carpet W/ 2 layers of sound proofing
I might even make the next one...
