Suddenly-high temps
COS80
The People's Republic of Colorado
My supercharged LX has the blue fan clutch, a recently-replaced radiator (factory), and the coolant is fresh, red Toyota-spec, and is full to the fill line, with no leaks. I haven't changed anything under the hood recently. The PO did the mod to make the temp gauge read true, so it has always pointed to about 4:00 when fully-warmed. Last weekend, it climbed to just below the red on a long ascent in high range, but it went back to normal (4:00) once I put it in low range. It did the same thing today, under similar conditions. Is there anything I can check, or is this just because it's 90*F and I'm running the A/C? I don't recall seeing this behavior last summer.
Use a scan gauge etc to verify true temperature reading. Or an infrared temperature gun to read the temperature at the radiator hose outlet if it rises higher than normal again.
Cool that you have the temporaries gauge modded, but does 4:00 = 200⁰f or 220⁰, or 250⁰f
My wife recently had temperature issues in her car on a long road trip in 100⁰ ambient temps without me. She was able to read real time temps using a code reader app.
Coolant temp was very high, but being able to read the actual temp in real time, we could see the temperature was stable, and still below a boiling point. So i told her to continue driving and watch the temps.
Later figured out there's an issue with the secondary cooling fan, dual electric fans in her car.
I should have mentioned that 4:00 = 186*F. I actually have a ScanGauge II, but it mysteriously stopped working just a week ago. I do have a scan tool that does real-time data - I'll install that.
I looked back in old emails, and found that the PO also modded the blue fan clutch with thicker oil. There is no trace of a leak on the clutch.
So, I guess the real question should be, what's the true temperature when the gauge is just below the red?
186⁰f is well within normal operating temp range
I lost silicone fluid out of a clutch I modified. There's was barely any visible sign it had leaked, and it leaked out all within a week or so, not slowly over time
A long climb in high range with AC running equals greatly increased heat load on the cooling system not to mention the fan turning slower due to high range. Even the transmission was adding extra heat due to the additional torque converter slip induced by the high range gear selection. I wouldn’t go getting all wrapped around the axle on this just yet. Seems like you solved the problem by switching to low range.
Right. I just drove it now with my scanner - it got nowhere near the red. Dead level is 195. The issue is I don't recall ever seeing dead level before, never mind approaching the red, in any conditions - I don't understand why I'm suddenly seeing this gauge climbing like this. Maybe it tossed the clutch fluid like yours.
Maybe I'll go do the same trail again tomorrow to see what it gets up to.
I've been playing with my blue clutch... bought one, swapped out oil (10k cst) and set the valve opening (105*F), and I'm still considering tweaking it for a little later opening. I've been watching on the hot days trying to get it to spike as high as I can. So far, the max I've been able to get is 196* on a 93*F day, on a long hill, ragging it hard, with the AC on. Most of the time, it sits right around 185*, and if I'm running down a long, steep hill at highway speed, it might drop down into the high 170s on a cool day. I can't get it over 190* unless it's pretty hot outside. Sounds a lot like your results to me.
I repeated the same drive today, with the scanner connected. The worst it got was 217*F. A little high, but certainly not the emergency the gauge depicts. I think I will get by fine as it is, for a little bit, anyway.
I still don't like this sudden variation, so I decided it's time to pull the trigger on an e-fan conversion. I did this on my pickup, which was the best thing I've done to it, so I always intended to - it just got moved up the order to "next".
Does anyone happen to know the I.D. of the radiator inlet hose?
What viscosity oil is in your fan clutch? The word around town is go with 20k in the blue hub clutch. I’ve only ever run the black hub clutch that has a much larger oil shearing area so 10k with no thermostat mods worked well even in hot temps. I’m going to a blue hub clutch on my current build and plan on using 20k oil and no other modifications.
No idea - the PO made the mod and provided no receipts.
I’d be opening it up and dumping the prescribed 45ml of 20k oil into it.
If I remember what I read correctly, 10k was Toyota's OEM spec for hot climates (as opposed to 3k for NA), though they also get the AUX fan for the AC. When I went to 15k, I noticed a dip in my mileage compared to the worn out fan clutch that was in place. Switching to 10k brought some of it back. 20k seems like carrying the "more is better" philosophy a bit too far, but I'm no expert and I'm also not supercharged. Forced induction might need more help.
Thanks for these tips. I realized that the 80 is really shallow between the rad and the pulleys, so I'm going to have to rethink my e-fan. I still want to do it, but it might not be so easy.
^this^ all day long. I would seriously consider staying away from an electric conversion too.
I have both the modded for accuracy gauge, and a scan gauge. The accuracy of the scan gauge has made me virtually ignore the factory meter and confirms nearly always that using it for anything beyond a very vague representation of the actual coolant temperature is pointless.
Don't bother with an electric conversion. Add 50ml of 10,000 CST minimum silicone oil to a fully drained blue hub and enjoy.
I suppose 20k May be overkill for an 80 that lives in northern areas and rarely, if ever, leaves it’s home area. As I stated before, I’ve had two black hub clutches open and the oil shearing area is at least double the area, if not more, than that of the blue hub based on photos I’ve seen of the open blue hub clutch. Anecdotally, then, 5k oil should be sufficient for a black hub clutch in hot climates as far as Toyota is concerned. In accordance with info posted by the experienced folks down in Arizona I filled my black hub clutch with 10k and she would pull some big air when hot keeping coolant temp under control. Start up plus two minutes is about how long it took to disengage after sitting over night.
Gas mileage? What’s that? I think mpg would be more adversely affected by modding the open up temp of the clutch thermostat leavening it engaged much more of the time. The way I see it, leave the timing as factory set, run an oil weight that will affect a strong clutch engagement to drop the radiator temp quickly so the clutch disengages as soon as possible.
My assumption is that the fan clutch comes timed to work in sync with the thermostat anyway.
So, as for timing, I'm a little rusty on this sort of thing, and I certainly don't remember the correct terms, but I don't think the fluid dynamic shear effect we're talking about is linear... I know it's a curve with regard to speed, and I think with heat as well, so the valve timing is acting on a different part of the curve with a different viscosity anyway. Also, viscous clutches don't ever FULLY disengage and they don't ever really FULLY engage. As far as startup goes, honestly, it was every bit of two minutes (probably more) for the blue to stop pushing hard with 15k.
Another thing to consider, I'll bet there was a real "factory" spec for settings when these rigs were new, but I'm pretty sure they're just slapping them together roughly... *here* (waves hand toward a general area) these days. I assume the adjustment was there in the first place to allow for variance in the bimetal spring to match Toyota's opening spec, but I doubt they bother if you just buy a regular Aisin now. I've heard of a lot of variance in the "stock" setting mentioned in several of the threads. It seems to be all over the place.
As for mileage, when you're only getting 14, losing another 1 mpg hurts! I tried a few different timing settings on the 15k and my experience was that it really didn't matter where it was set, it was pushing a lot of air even when it was as fully disengaged as it gets... to the point where my OBDII gauge was showing the difference in temps, even with higher opening settings that I tried.
With the blue vs black comparison, I have no idea how that breaks down. Honestly, aside from how MINE behaves in MY RIG, it's all glorified speculation. I suppose we could build a fan clutch dyno... anyone want to slap some load cells onto one and fire up some data-logging software?
Anyway, I'll go back up if I ever feel the need, but I'm waiting on a few of those 100* plus days that we sometimes get to drive it hard with full AC. I've had it in and out like a dozen times in the last few months, just playing around with it. I'm not afraid to try again, but as noted previously, Toyota thought 10k was good enough for the middle east and Australia. I'm not too worried about it. Just sharing my experience.
