- Thread starter
- #21
Did you unbolt the door from the hinges or the hinges from the body?
Mine is on the driver side (and broken off). RHD.since we are talking antennas, i have two, one on each fender, which one is considered stock? drivers or passenger (RHD). same stock manual type....
yea me thinks due to snorkel, PO installed another on the pass side, as the snorkel head makes contact with the fully extended antenna. However, when redoing my radio, i used the RHD side and extended it 3/4 of the way and it works fine reception wise. So now i have 2, one just isnt used.Mine is on the driver side (and broken off). RHD.
View attachment 1442807 No fender removal.
No pain and suffering.
Protects your Cruiser from low flying birds.
Picks up radio stations from far far away.![]()
the antenna receives the radio signal and sends via coax cable to the back of the radio. same as most, just need to run the cable and have the right connector at the endAt risk of this being a really stupid question... how does that antenna send signal to the stereo? Wires running through engine bay > firewall > into stereo? Wireless?
Microwave repeater. *At risk of this being a really stupid question... how does that antenna send signal to the stereo? Wires running through engine bay > firewall > into stereo? Wireless?
Charles needs his AM oldiesMicrowave repeater. *
* I just made up that part.
The antennae wire runs through a common loom with the driving and fog lights and spits off once it enters the engine bay.
I'm sure you meant to say AM/Cassette.Charles needs his AM oldies![]()
My antenna on my FJ73 was broken off, then the screw was lost after an attempt to JB Weld it all back together. I don't think mine is OEM but either way I am going to have to replace it. I am seeing a lot of conflicting information but it seems like there is no proper way to actually replace it without removing the fender. Anyone have documentation of doing this without removing the fender?
