So what fluid did you use? ATF or Power Steering fluid?
I hope he's using ATF, since that is what is in the specs.
Awsome write up was going to tackle rebuild as my input seal leaking also my pump and resevoir thought I would just try the brake fluid trick seeing I had nothing to lose. I added bout 100 mills to resevoir and I have had no leaks since Fkn unbelievable I definitely recommend giving it a go before spending $ on the rebuild
True the kits are pretty cheap for both box and pump if you can do it yourself. Will get pretty exy if you have to pay someone else, for now bit of brake fluid seems to have softened all the rubbers and seals on both box and pump on my cruiser and stopped leaks will keep the rebuild kits on hand thou not sure if it will be long term fixI think the rebuild kit is about $26 from rockauto. Pretty cheap and about a days work.
RTH: So I am doing this today. Do I really need to remove the steering wheel? If not how do I remove the shaft easily.
I didn't remove the steering wheel on mine. Unbolt the shaft where it slides over the gearbox, unbolt the gearbox and you should be able to work it forward and out. When I did this though my engine was out, so your results might vary.
Okay. I'll give that a shot. Any other ideas appreciated.![]()
So I got steering box out....separating the steering shaft from the input shaft took me an hour and half. I should of removed the clamp bolt and soaked it with penetrating spray for at least an hour or more. The rust rally kept it on there good.
Thanks all for the help I will post a step by step with pics to help others![]()
So i have the piston and balls in and th bolts tightened down then I discovered a ball on the floor... does missing one ball affect anything? (no Lance Armstrong jokes please..lol)
one thing I forgot when i did mine was to mark the splines before you pull them out that way your steering wheel stays straight when you get it back together
