Steering gear box rebuild (4 Viewers)
Part numbers:
Spring: 90501-20095
Plunger: 44152-30020
Plunger guide (not the nut): 44153-30020
I just finished this rebuild but the preload guide in the fsm must be joking. With all the new o-rings and teflon rings, the input shaft wasnt easy to turn at all. I guess i wont know until installation but come on.
Also, one tip with reloading the 44 balls is really goop on the ATF. The balls need lube. Went much faster after this was done.
If you have the correct spanner/pin wrench, you could get away with not taking all the balls out even if you must replace the input seal.
  • Like
Reactions: RFB
Update on whether the preload was too tight?
on step 8 where the teflon ring wants to hang up i took fine emery cloth and softened that edge.
this help as well as slightly rotating it as i pushed i past that edge
i could feel several tiny burrs,not sure how toyota got it in without tearing it up but i did notice on the old one it looked as if it had been damaged on installation.
good tip, thanks. I'll be doing mine as soon as I find a donor box to play with.
well crap,i opened mine back up to check some seals,lost the ball bearings and 2 piece tube that goes on the power piston,had it sitting in a small plastic container on my work bench,time to go through my dictionary of foul language and repeat every word at least 10 times....................
So i just did this rebuild and also did the 105 sector shaft upgrade kit from @Akella at the same time. Thanks @96r50 for your step-by-step guide on the rebuild, phenomenal job. I also watched this youtube video by Samuel Bishop - wasn't done exactly the same way that Adam did it but it was very helpful to watch.
I think in some earlier posts there was a question if the Toyota kit came with the input shaft seal - it does. I ordered a Gates kit just in case...they are identical in terms of what comes in the kit. See pics below.
Toyota Kit:
full
Gates Kit:
full
When I did this rebuild I also bought a new power piston plunger nut. I would say It is a must for the rebuild.
full
Toyota Kit:
full
Gates Kit:
full
full
Curious what the cost difference was?
The Toyota one came with the kit from @Akella but it can be bought for ~$150 + S/H online. The Gates kit I got from RockAuto.com for ~$20 + S/H. I used the Toyota kit in my rebuild.
Toyota Kit:
full
Gates Kit:
full
full
AWESOME, thank you for the feedback and also more encouragement for those of us who haven't tackled this task!!!! :clap:
Curious what you did differently from the YouTube fellar, who is very entertaining BTW!!
After 2 weeks I got my order, did unpack and found the 4 teflon seals inside and they fit, YAHOO!!
Most of the other rings and seals where from another type of gearbox I think. Don't know what I did wrong but for me it's ok, I have what I need and started to fix the gearbox.
For those who didn't put a teflon seal on this kind of device, this is what my mecanic (old guy) did.
1, Throw the seals in a plastic cup within a layer of steering oil, drowning them, after a couple of minutes stretch them a little with the hands and throw them back and wait a day.
2, Put them around he shaft and work/stretch them SLOWLY and GENTLY with a thin pick on the first spot for the seal (don't know the name of the pick but a dentist have the same thing but luckaly they're pick is smaller, lol)
3, Keep moving the seal to the last spot on the shaft and pick the next seal till you have all 4 sitting where they belong. Than leave the shaft for a cup of coffee or a beer, let the seals shrink a little for a couple of minutes.
Now they are still stretched and your officially need a tool to shrink them again, DO NOT JUST PUSH THE SHAFT IN! you'll break them for sure.
If you look close to the inside where the shaft needs to go, you'll see that in the beginning it first slopes a bit, it's not a sharp edge.
4, Put some steering oil where the shaft needs to go and also on the edge.
5, Put the shaft in up untill the first teflon seal and GENTLY press and turn a bit, it'll slide in.
6, Gently turn a bit and try the next seal.
7, Gently turn again and,.. slowly take the shaft out again, you'll see that they shrunk a bit compared to the other 2
8, Put more oil (see point 4) as you'll notice it's getting a bit dry
9, Try the rest and keep in mind, GENTLE and SLOWLY and keep the steering oil coming, it'll be fine :D
This is how we did it. Car drives good again and no more troubles!! (exept that I had to change the oil seal for the driving shaft.. yes the one behind the pully for the timing belt... AGAIN... but it's good now lol)
Can you send me the PN for the complete kit? My mechanic broke 2 of 4 teflon rings on the input shaft and the Kit that I bought from rockauto doesn't come with those rings
Real time help need..
Need some help with my gearbox rebuild. I managed to get the bearings and tube back in but noticed it unwinds but its hard to close the piston back up closer to the input shaft housing, seems to be binding somewhere in the bearings. I figured it might be binding since its not in the piston sleeve. But when I put it in the thing still binds and only wants to expand. Has anyone else had a similar issue? Do I need to pull apart and re-install the bearings? I didn't lose any bearings...
Any update on this?
Any update on this?
From what I figure, the balls ride in basically a twisted circle from the worm gear through the tube. When your working them into the worm gear one of them can fall out of that area where the tube sits especially in the hole on the side where the gear goes into the piston. I saw this when loading them. It's a pain in the ass but if you keep that in mind, you can carefully load and work them around the gear and use a small screw driver to push the one that might fall out of that area. I got it on the 6th or 7th time. When it jams there's one ball not where it should be. Hope I explained it kinda hard putting it into words.
Toyota Kit:
full
Gates Kit:
full
full
Great post.
Hello, Friend, I have a technical consultation, the repair manual says that the box should be filled with SAE 90 oil approximately 640 cc.
The one that I repair. and posted on the forum put SAE 90 oil.
