Steering Flush & Cleaning (9 Viewers)
Just did this job + all new hoses and clamps.
I went through this thread pretty thoroughly, so if this has been covered feel free to roast me.
I found a cheaper alternative to getting a replacement reservoir for these trucks if you aren't in need of the metal bracket. I can thank an old Motorweek review segment of the 2006 Pontiac GTO for this. This reservoir is used in many vehicles so after seeing it under the hood of that GTO I dug up a P/N.
GM 92202130
I received the part yesterday and can confirm it's identical to the reservoir in our trucks. They changed the labelling on the cap to just a couple info graphics, but that's irrelevant to me.
Wow! You have telepathy powers!
We had a GTO at work for sale until a few days ago, and since it drained it’s battery while seating , we had to jump start it all the time.
I saw the reservoir and googled it to check it out, even tried to find similarities between them, and was about to post here to ask if someone tried one. Just got busy, the GTO sold and I completely forgot about it.
Thanks for the reminder!
Rhetoric - thank you for providing the part number for the GM power steering reservoir. I just swapped a new reservoir in this evening after flushing my steering system with 3 quarts of new ATF. The reservoir costs $38.79 on Rock Auto, with 7.99 for priority shipping. Total cost of the fluid was less than $20.00, so overall a very economical way of replacing the old/stock power steering reservoir. (Mine was an ugly yellow color after 24 years of life on the 2000 100 Series.)
Did mine this week!
I simply unplugged the lower hose.
Filled it with 400ml to max cold.
Drove it for a week.
Drained & filled 400ml again today.
Fluid from Toyota dealer, $10.
I used to think the steering was heavy because of the 35s, but now it is much better!👌🏽
Even though i noticed the difference in steering feel after changing the fluid with Mobil ATF, I found a bottle of Redline D4 for $10 on facebook and decided to do another exchange
Glad I did!😃
The difference is huge! Steering is much lighter!
I overfilled it but didn't notice the fluid expands when hot, I guess because it is synthetic and the extra fluid helps with keeping it cool
Glad I did!😃
Best to not overfill.
Watch level during first step of bleed (engine off, tires off ground) level drops and raises. Too much fluid and it find a way out of reservoir (cap and or hoses)
BTW: Mobil (not all are full synthetic) is not the same as Mobil 1 (all are full synthetic).
If I was going to install PS inline filter. I would use a PS inline filter. They have almost no flow restriction and powerful magnets.
above link, is to a good one of the magnefine line. Magnefine has even better and cartridge type.
Man, what a great little project! And what a nice improvement!
This is also yet another reason to love these forums due to the great finds by @Rhetoric for the reservoir and @Tareq for the Redline D4 tip. Thanks guys!
Oh yeah, and also thanks to @shtbrwn86 who found the return hose with Breeze auto. I didn’t feel like driving all around town trying to find the right hose at an auto parts store so I just ordered from Breeze and the hose works great. It was a little tight getting it onto the new reservoir, but it wasn’t bad getting it onto the hard lines down by the rack. (More here if you want to order from Breeze)
I’m not sure how much improvement came from the redline D4 itself, but there is for sure a small but noticeable difference in lighter steering effort after doing this change! I ended up flushing through ~3 quarts before calling it good. So glad to have some good synthetic in there knowing how much heat this fluid deals with.
I also don't know if my rack has ever been replaced or not. The boots are still dry, so fingers crossed this fluid change will help it last a little longer.
My parts list for my 2001:
New ReservoirGM GENUINE 92202130Rock Auto
Return Line (2003+ is different)3/8" ID Conti HoseBreeze Auto
Feed Line44348-60240OEM Toyota
PS Fluid (ATF Fluid)Redline D4 ATFAmazon
Seal ReviverAT-205Amazon
Feed Line Clips90467-21010OEM Toyota
Return Line Clips90080-46355OEM Toyota
My final photo looks almost exactly like @Rhetoric lol
Who knows if or when this has ever been done on this truck. The fluid was absolutely black with clearly some not so great looking sediment in there.
glad I stumbled on this thread...I just rolled over 265k miles and pretty sure this has never been done...love this forum!
Will the OEM Toyota cap fit on these GM reservoirs? I like to keep things looking as stock as possible and my cap is still in good condition.
This should be in the FAQ
Can someone educate me on why Toyota ATF (00718-ATF00) isn't popular here? I noticed most use Mobil 1 ATF. Just curious if there is a specific advantage with one vs the other?
I cannot speak for others… but for me, the Toyota ATF is $13/ quart, and reportedly is not a full synthetic oil… group 3 base stock blend.
Whereas Valvoline Maxlife ATF is indeed a FULL synthetic oil, and has utility outside the Toyota WS classification
And
Amazon has 3 gallons for $78. That works out to 1/2 the price of the Toyota fluid.
Granted, the power steering system does not have much fluid volume, but at $13/ quart for synthetic blended lesser quality fluid, it adds up fast for drain and fill of transmissions when you have multiple vehicles.
The not so secret trick to make your power steering system last for much longer is to keep it cool. For more information, see post # 233 in this thread.
I am OEM parts, all the way, but I can’t use Toyota’s lesser quality ATF product at 2x the price point.
Just my thoughts during confession.
