Steering Box Spline Specs
Harbour City, the New Southern Wales
Website
www.freewayoneentertainment.com
Converting an early one-piece column to a later two-piece column-and-box arrangement [retaining the original column inside the cab] and with the parts over 1000km away I'm struggling to determine the u-joint I need to buy.
Does anyone know the size and spline count of the 40 box where it mates to the column? If it's any help it should be the same size as 60 and 80 series boxes. They're usually measured like so:
Diameter/Spline Count
17mm/36 splines
.750"/48 splines
Cheers!
I’ve got my original box on the shelf from my 77 and can check this afternoon if you don’t get a hit
Yes please sir. I'm not sure if the diameter measurement is in lieu of or includes the splines - could you perhaps get both?
Mine still had the original rag joint on it. Looks like 32mm and 36 splines. My box is the original from my 08/77. Here’s some photos.
Hope it helps
@77mustard40 thanks mate! Pic #2 - is that 17mm which is equal to .760"? I worked it out differently.
Well 17mm / 25.4mm per inch would be .67”
Yeah that's what I thought! :) Was wondering which measurement to use as I'm not so used to callipers. I'll go 17mm. Thanks mate!
Mine reads 17.433 mm. I'm unable to count splines with it in place with the rag joint on.
btw, .760" converts to 19.304 mm.
Online Conversion
Thanks fellas. Lol, so now we've got 17mm, 17.41mm, 17.433mm and .760". At least we can agree on 36 splines :D
We'll, since the difference between 17.433 mm and 17.41 mm is less than 6 ten thousandths of an inch, you could justifiably consider them to be validated as equal.
We'll, since the difference between 17.433 mm and 17.41 mm is less than onone pers thousandth of an inch, you could justifiably consider them to bebe validated as equal.
Yeah, just being facetious :D
Thanks @snaggletto I'll check em out.
@cult45 did you find the correct universal joint for your set up?
I'm looking at adapting my 80 series steering shaft to a 40 series column and found a borgeson uni joint with a 11/16" 36 spline to a 3/4" DD and was hoping this will suit my needs. I will have to cut the 40 series column shaft and grind to suit the DD.
I used something readily available down undah which is the 70 series OE uni. The larger end of the uni is the correct diameter for the 40 shaft and smaller end correct for the 80 shaft (I believe). They used to be $20 apiece but these days they’re around $80 AUD. Amayama should stock them as well.
I have an 80 series universal joint which suits the correct splines but trying to get a 40 shaft resplined at a resonable price is proving difficult.
45209-60070 is the 80 series Uni joint was close to $100 from amayama delivered. Wish they were still $20 that's a bargain, would you know the part number?
I have to sort out a shaft for my 71 SWB as its just welded at the moment and have a power steering set up to go on the HJ47.
I did find these available in Australia for a good price.
