Steel wheels were discussed last week in two threads(mine and Photoman's). Here's the additional info I learned the hard way...
Last Friday I bought 5 Rock Crawler wheels. The bolt pattern was right(6x5.5), the offset was 0 and backspacing 4.25 - close enough. Center bore was 108mm vs 106mm for OE. OK, that will fit.
Then I noticed that my factory alloys used flat washers on the lug nuts instead of conical lug nuts. The Rock Crawlers were set up for the conical type. So I called Toyota Customer Service and confirmed my suspicion - 80's are hub-centric. In other words, the wheels are chamfered to fit tightly over the tapered hubs. The hubs are weight-bearing. After-market wheels will bolt up but the lugs bear all the weight.
Can't say for sure, but I doubt that any after-market wheel mfg makes hub-centric wheels for 80's. Also, I don't know if all model years of 80's are hub-centric, but '96 sure is.
Took the Rock Crawlers back and stopped at my friendly toyota dealer on the way home and ordered the factory steel wheels.
Ed
Ed
