Wait til you have to lift one up onto a rear tire carrier...
Riley said:Put a 33" MTR on a OEM steel wheel and it's freaking heavy. It's easy pulling them off but putting them on is a challenge (to me anyway). Kinda of awkward lifting and positioning on the studs.
Time for some weight lifting I guess.
e9999 said:I just lift it up, but wood board on 2 pieces of tubing under axle, put wheel on board, slide wheel onto hub, done...
E
Riley said:I've been thinking something along those lines but never done it. So I guess you're suggesting that wood slides on the tubing as a roller?
Only problem then is to get the axle height just right so that it all lines up.
T Y L E R said:And if you're in play clothes .. just sit your ass on the ground , with legs in front of you . Place the tire between your thighs , and use your legs to 'lift and control' the tire onto the hubYour thighs alone ought to raise the tire quite a bit .. then just start bending your knees up to make the proper adjustment .
TY - Absolved of any responsibilty here![]()
White Shark said:Roll the tire to the hub. Lay the end of the lug wrench on the ground (preferably a 4 way, not the stock pos), and roll the tire onto the end of the wrench below the hub. Use the wrench as a lever (reverse fulcrum) with the wrench end on the ground, with the tire a few inches above and your hand a foot above that. Lift the end in your hand using the wrench/lever, thereby fitting the wheel onto the hub. You can reduce the perceived weight of the wheel by about 75% allowing the placement to occur by manipulating the wrench up and down. This is an old tow truck driver / Highway Patrol method of tire changing without killing yourself. Removing tires works the same in reverse. You'd be amazed at how little effort is required to change a 35x12.5 bias ply swamper on a steel rim (100lb.+) this way.
