Starting problem for 1991 Fj80
Hey all,
My rig has recently been having problems in the starting department, ever since i got it, it has been having the "Click" issue and about a month ago it has just not started at all. i have looked at the starter and it appears to be in good shape mechanically and electrically. I also read that most toyotas have a starter relay but i cannot find mine.
Hoping y'all can help,
C Dizzle
Here's what I could find on relay location. See if it helps
Edit: just saw this was for a 91. The attachment may not be exact in that case...
Hey all,
C Dizzle
There is no "starter relay".
If you're hearing a firm click from the starter when you turn the key to start, then the starter logic is good and the contacts are likely bad.
This has nothing to do with the check engine light. The starter circuit is separate.
