1991 fj80 will start but dies.
Alaska
Heya, I just recently got my 91 fj80 back on the road. It was running alright. Idled fine in park but would drop idle to 450-500 rpms when put in gear. Recently will start but not Stay running unless I'm on the throttle. I can hold it at idle but as soon as I let off the throttle she dies. I've cleaned and inspected the ISC. All seems fine there. I haven't found any vacuum leaks. It happened quite suddenly while driving.
The intake tube was cracked in several places. I patched it up and wrapped the :censor:out of it with electrical tape. Haven't messed with the afm.
You still have an air leak. The top end of the motor wants to be air tight.
Thanks for all the info. I had time this weekend to dig back into this. I've replaced the intake tubes with hps silicone tubes. Checked the maf, all good. Checked the tps, all good Checked the isc, all good. No vacuum leaks that I can find. It is desmogged. Will start right up but not idle. Any other suggestions?
Idle control valve?
