I've been trying to start my 40 recently after working on refreshening it for the last 10 years. (still not done but getting closer) The last time it ran was in 2013. Since then I've replaced the cobbled-up wiring harness with a nice original. I have the ignition circuit hooked up but I'm not getting it to crank when using the ignition switch. I can start it if I set the switch to the "run" position and manually jump the starter with a screw driver. And it will not run if I turn the switch to the "off" position. I don't have the majority of the remaining harness connections installed. (I just made sure none of the connectors were in contact with anything they shouldn't be).
I'm running a ’81-’87 distributor, ’78-’80 igniter, and a 60 alternator.
I suspect it could be a ground wire in the harness that isn't connected and will investigate that tonight. Does anyone have any other ideas as to what is causing this condition?
Also, It's nice to be back on mud. It's been quite a while since I've been on or been able to work on the 40.
thanks
thanks
