1. Swap the metal fuel return pipe that's bolted to the back of the engine for a soft fuel line affixed up on the firewall, insulate it.Sorry, I'm lazy. Quick summary of what you did to FIX?
Interesting… I get #2-4, but what does changing out the fuel return pipe do? I assuming you mean the pipe that takes excess fuel, beyond what is needed by the fuel pressure regulator, back to the fuel tank.1. Swap the metal fuel return pipe that's bolted to the back of the engine for a soft fuel line affixed up on the firewall, insulate it.
The return pipe is steel and bolted to the back of the engine. So basically it gets as hot as the hottest part of the engine bay and it's steel so it will transfer that heat into the fuel very effectively. It's a good 14 inches or so.Interesting… I get #2-4, but what does changing out the fuel return pipe do? I assuming you mean the pipe that takes excess fuel, beyond what is needed by the fuel pressure regulator, back to the fuel tank.
we’ve tried everything, and yet the simplest thing and cheapest thing to do first is bypass the fuel pump resistor by just soldering the 2 wires together, most 100series don’t come with the extra resistor anyway.The return pipe is steel and bolted to the back of the engine. So basically it gets as hot as the hottest part of the engine bay and it's steel so it will transfer that heat into the fuel very effectively. It's a good 14 inches or so.
and we’ve been colorado wheeling for 2 years no issues after soldering the resistor on top of imogenewe’ve tried everything, and yet the simplest thing and cheapest thing to do first is bypass the fuel pump resistor by just soldering the 2 wires together, most 100series don’t come with the extra resistor anyway.
OK, I assumed that. So is the working theory that one of the causes is that return fuel heated by the engine gradually heats up the fuel in the tank, along with heat from the exhaust? That definitely makes sense for one of my stalls (at less than 1/4 tank), but two other instances happened with over 3/4 tank.The return pipe is steel and bolted to the back of the engine. So basically it gets as hot as the hottest part of the engine bay and it's steel so it will transfer that heat into the fuel very effectively. It's a good 14 inches or so.
It just comes down to heat. The thing about the 100 is that there are multiple places where heat can get into the fuel. Limiting the heat or trying to remove it is the best way to solve this problem.OK, I assumed that. So is the working theory that one of the causes is that return fuel heated by the engine gradually heats up the fuel in the tank, along with heat from the exhaust? That definitely makes sense for one of my stalls (at less than 1/4 tank), but two other instances happened with over 3/4 tank.
Resurrecting this thread... I want to tackle this problem on my LC 100 now. I have some time on my hands but my access to a garage space to work ends soon (April 18).It just comes down to heat. The thing about the 100 is that there are multiple places where heat can get into the fuel. Limiting the heat or trying to remove it is the best way to solve this problem.
Looked back at your post and you said it has happened when it was 104F both times. I think that pretty much seals it as a heat related issue.
Thanks for posting! I'm planning to do the fuel pump replacement and do as much of the fuel line insulation as I can next week. I ordered the DEI insulation for the lines. The metal lines are Dia. 8mm, and the rubber fuel line from the fuel filter to the fuel rail is Dia. 12mm.Had this same problem with my 2006. The advice here was helpful. I did 2 of the items - plus replaced my fuel pump. Here is the insulation I used for the tank and lines. Seems to be working.
