- Thread starter
- #21
It is the *50160 BTW: Engine shutting off during long trips.
For 2006-2007 LC/LX, the fuel pump part # 950-0210 is the one I used. The o-ring seal is included in the kit. Clamps are all reusable.Bumping this thread again, which is the right fuel pump for a 2006?
- Which fuel pump? The P/N is 23220-50160 for the new one? There is another listed from 1998-2006 of P/N 23221-74110 or also P/N 23221-66040? Which one?
- What other parts are needed to do this job? Seals? Clamps? Are there other things I'll need than what come with the pump?
Classic sign (after climbing hill, as you let off gas pedal. It dies!) in the 06-07, of a bad fuel pump.@Pskhaat @ OEMGUY0720 how is it going guys with pumps? I have a similar issue: sometimes it stalls after 1 hr of driving on a highway and then ascending from 2k to 8k altitude. I stop the engine on a viewpoint parking, walk around about 10 mins, they try to kick it off, it starts, burps and stalls. No gas smell or something unusual. As far as I can tell it only happens sometimes after climbing high hills. I then wait about 10-20 mins and start it with no issue. Never stalled when driving though. It's 2007 LX470 with 150k onboard. I think I will replace the pump with #23220-50160
Thoughts? Warnings?
Posting your rigs year, miles, stock or built and with what mods, is helpful in remote diagnosing. Better yet, add vehicle info to signture line.ok. So I will kick this can again. Today I had a trip to the same place I used to stall. I call it a "vortex place" since there my truck dies. Ok, to be fair it had stalled a couple of other places too. But I can bet a hundred it would stall there. And the truck is always good in other placesNever stalled when driven. But the symptoms are the same. So today it happened again.
With a brand new just replaced fuel pump (Denso) and new underhood fuel filter (Toyota). It was at about 8k feet altitude after climbing from 4.3k (Salt Lake City). About 95F at the highway, 75F at the top. But today I really noticed a fuel smell near the cap and saw fuel vapors coming out the cap. So I think it somehow may be related to air pressure at high altitudes. When I got down back to the city I did not see any fuel vaporing near the cap and the smell's gone.
So far for LX470 2007:
Cruiser works and runs nice all the time. No stall being driven. No hard starts. No DTCs whatsoever. Only 91 fuel. I normally go to the mountains for skiing winter - no stalls and no issues. The problem occurs at even moderately hot days, at high altitudes, and seems somehow connected to vaporing fuel and atmospheric pressure.
- replaced PCV
- replaced coolant cap (OEM) and gas cap (OEM) about 15k miles back
- cleaned MAF, throttle
- new air filter
- replaced couple vacuum hoses (looked bad)
- replaced pump and fuel filter
- fuses look good
Thoughts?
forum.ih8mud.com
Thanks! I really appreciate how passionate you're about answering questions. Sorry for being misleading. It's a 2007 LX470 Stock 146k miles on board. Added to signature as well.Posting your rigs year, miles, stock or built and with what mods, is helpful in remote diagnosing. Better yet, add vehicle info to signture line.
The fuel pump issue of stalls after ascending passes or long acceleration, is predominately 06-07 issue. Which I assume you have based on fuel pump you installed.
Fuel boiling can happen in any year, but we see varrition in 98-02 vs 03-07.
I've found coolant system number one consideration, tune number two, build number three.
Number one:
Cleaning old radiator with ~250K on them, that have really gotten clogged fins. Will save in parts cost, but labor time about the same as R&R (remove & replace). R&R is more effective and better use of time.![]()
Radiator fins need cleaning! Alert Alert Alert
I've a 06LC w/192K I just bought. In reading history I found PO complained of engine temp raising when both front and rear AC on. Toyota Dealership diagnosed with clogged radiator fins. Recommended new OEM radiator, $600 for the US spec Radaitor plus coolant and labor. They should have added...forum.ih8mud.com
Once a fuel boiling issue has occurred, my thinking is; "it may have affected the EVAP system" More so if 03-07, which has charcoal canister in rear.
First thing is to log ECT (engine coolant temp) during normal driving and at times vapors noticed. Dash water temp gauge is useless!
Where is said resistor?Hello, im too lazy to dig up the thread that i was active on, on the subject. But i may have discovered our problem. Ive always had the suspision in the back of my head that it had something to do with the fuel pump resistor. Now let me explain myself. As temprature goes up and the resistor is in line with the pump (being heated because it is in use) the resistance of the resistor changes. This is why it doesnt stall when youre deep in the accelerator, because when youre under heavy acceleration the fuel system goes into an open state and circulates fuel back to the fuel pump. But as soon as you let off the gas and the engine isnt using as much fuel it goes into a closed loop, Putting the resistor inline with the fuel pump to slow it down, but because the resistor is above its operating temperature the resistance is higher than it is supposed to be not letting any amperage get to the pump. Now my best idea why the car runs fine on ethanole free gas is becasue with my expierence the car runs a little cooler on ethanol free gas. inorder to solve the problem once and for all i extended the wires to the resistor and relocated it to the airbox where it will always have access to fresh air. weather this will solve the prolem we will see.
it is mounted inside of the engine bay to the passenger side fender. looks like this. Fuel Pump Resistor for Toyota Land Cruiser FzJ80 Lexus LX450 93-97 RESISTER – JT Outfitters - https://www.jtoutfitters.com/product/fuel-pump-resistor-for-toyota-land-cruiser-fzj80-lexus-lx450-93-97-resister/Where is said resistor?
I'll have to try that, in a thread a while ago I read about some people that were trying to bypass it all togather, but they didn't know how to do it and I didn't expect it to be that easy. would keeping an extra plug hand to swap in when the cars shut off be smart?a couple more things need to be measured before a conclusion could be made about how hot the resistor gets related to fuel pump voltage drop.
if you don't like the fuel pump resistor, bridge the connector and remove it.
it's suppose to get hot enough to scorch your fingers so keep it away from anything.
the pump, resistor, and the wire length and gauge were proper when it was new.
that doesn't mean it's proper today, plus fuel is different today than it was then.
If one of you guys that drives over big rocks at idle speed with a 06-07 would like to try taking out the resistor on one of your runs and see what happens with the boiling issue it might be very enlightening, or it might affect nothing.
just to keep pump wear to a minimum. I guess you could also see how bad your stalling issue is and make a move to permanently hot wire it.I'll have to try that, in a thread a while ago I read about some people that were trying to bypass it all togather, but they didn't know how to do it and I didn't expect it to be that easy. would keeping an extra plug hand to swap in when the cars shut off be smart?
im guessing R&R means resistor and regulator?What's interesting, this would act much like the weak fuel pump we've seem so often in 06-07. In those with bad fuel pump, fuel R&R alone corrects.
But I do know on one, FP R&R did not correct. It does have a air compressor and battery tray, next to fuel pump resistor.
