There is no rhyme or consistent reason. I can be slowly driving around town. Or towing. Or slowly climbing well above treeline.
Hot weather and high altitude and ethanol fuels seem to be the only consistency. Though I've experienced this low at under 5k feet as well. I've changed fuel pump, wrapped fuel lines and added a 12v cooling fan to the resistor.
I'm convinced it is a fundamental problem with late model EVAP, placed too low in the system, and hastily/not tested by Toyota.
There is an issue with EVAP. Number one is contamination of CC.
So the fuel pump of the 06-07, act similar, but a bit different when bad. The test is on a hot sunny day. Pull up a pass in high RPM, for 5 or 10 minutes. As you crest the pass, let off gas pedal. Engine dies! If hook into tech stream at the time, do not turn off key. Check for DTC first. Either current or pending. We see BK 1 & BK2 lean. test fuel pump (by the book, fuel pressure testing, will not reveal)
Once they start rough idle or stalling, just driving around town on hot day. It almost always the Charcoal Canister (CC) is saturated (contaminated). We see a much higher instance in the 03-up. Which is when the CC was move to the rear. So yes, it is and EVAP issue.
The two worst cases I've seen, where I did check weight of old CC after replacement. One really bad vapor, boiling, rough idle, stalling 2005. CC was 25oz over. A second 2007, was not running as bad, but close. CC was 20oz offer weight. The overweight, is indicative of contamination (saturation with raw fuel in CC)
I can't stress enough. All system must be in proper working order, before replacing CC. Or we risk contaminating again. After which we must ahead to some rules, so we don't flood CC:
- Never add more fuel, after auto shut off of filling station pump handle.
- Maximum of 7/8 or less, tank of gas. When ascending a rocky mount pass.
- Avoid topping tank on hot sunny day. Unless drive about 30 miles as soon as you do, to draw tank down.
We also need to make sure ECT, AT fluid temp & fuel trims are all inline. If not something needs correcting.
If a heavy with under armored, especial bell pan. It can't hurt to do some shield, also.
