SQOD Squad - Stupid Question Of the Day (18 Viewers)
Anyone know the bolt sizes used for the 3rd row seats? I'm fitting some custom drawers and need longer bolts to mount the base plate
🤦🏻‍♂️ I just did this, but I’m only 90% sure it’s a M8-1.25 I used a 50mm and 45mm length.
Home Depot had them in stock
Thanks, I'll order a few of those, unless someone else says there's a different fit. For my setup I'm going to try some sidewalk/hurricane bolts so I can easily recess them
sorry! i just checked and they are M10-1.25.
the two bolts in the picture are 50mm, and I needed a 60mm for the one circled in red. However, i'm using a 3/4" bottom, so YMMV
Does the iPhone 12 PRO MAX at 6.7" fit in the iPhone charging tray and charge correctly there?
I measured it only the mini fits in where you can close the door.
Not sure if this is still an open question, but the iPhone 12 Pro Max does fit (with the door open) and will charge in the slot. However, I never use that charging slot because an iPhone gets HOT in there.
I’ll add to this one for future search purposes...
In a 2017 LX the iPhone 12 Pro Max does *not* fit. Even without a case it is too large.
Where do most people buy the techstream device/software? Seems like its all over the place
The known reliable adapter is the vxdiag, it’s on Amazon. The easiest way to get the sw is to download the virtual machine. Search on mud.
I bought this one on Amazon.
DIAGKING Toyota Techstream Diagnostic Cable Mini VCI J2534 OBD Scanner V2.0.4 for Toyota Lexus TIS Techstream Amazon product ASIN B07BCL3DFRThere are cheaper, but this is cable+software+they will literally remote in and install it for you if needed.
What is the usable amount of fuel in the LC200?
24 gallon tank. Fuel light comes on at 20, so you’ve got another 50+ miles til you really need to fill up.
I recently filled my main tank with 19.5 gallons after driving 12 miles after Ecu displayed 0 miles to empty (I average 10 mpg). With that run, I had 5+ gallons in the tank after 0 DTE
I've run mine down to zero twice now and have never gotten more than 19.5 gallons in at a fill up. And that with doing the extra few clicks that I think Toyota warns against.
I did a distance to empty test, running the tank to engine stall. I was able to travel 45 additional miles after the counter saying 0.
45 (local) miles at a typical ~11mpg city for my modified vehicle, represents 4.09 gallons left after the trip computer says 0.
With 4.09 gallons reserve:
Best case for a stock vehicle on the highway @18mpg = 72 miles.
Worst case I've had towing/headwind/hill @8mpg = 32 miles.
More details here
FWIW, having a total of 64.6 gallons rocks.
LOL .. so you finally got it installed cool !! We'll have to meet up some day. I take it you're in JAX?
The MAIN tank is 24 gallons and I've never put more than 19.7 in it and I'm wondering what is that limit on the tank before you suck air?
More details here
Before my LRA, I always went 30 miles past 0 and then filled up. This had me filling about +/-23 gallons each time.
11ish MPG for me, as well.
More details here
Thanks !!
Thanks is what I was wondering .. so approx 4 gallons plus my 19.6 means 23.6 usable.
Hey thanks for the diff's .. still on the bench but soon !!
  • Back
