here's a post from Jowett himself:
Then I read Jowett's webpage and found the 4th sentence, " the factory spring valve is eliminated"... I did not read it correctly, I guess confusing...
I’m not sure about rolling with it for 3k miles, maybe someone else can chime in about that; however, you can open the drain on the jowett and then unscrew it without draining the entire oil pan. You’ll only lose what’s in the jowett. also, if you really want to salvage what’s in there, you can drain it into a clean container and then put it back in the engine (personally, I would probably add a new quart).Thanks Radman,
So if the oil is brand new Mobile 1 and I always add a can of B G MOA (motor oil additive).
If a little oil is bypassing do you think it's good enough for 3,000 miles or so?
Thanks for your help, I owe you a beer if we cross track at some Land Cruiser event.
So all that to say: should be an easy 30 min fix by draining the jowett and putting the spring in.
On a 2019, no. Not sure for the models earlier than '16.Do you need to do anything after doing a 5 tire rotation to tell the car where the tires are now?
No the 2008-2015 at least doesn’t know which sensor goes to which location. I can tell the spare after driving a bit because the pressure will be different than the other tiresOn a 2019, no. Not sure for the models earlier than '16.
You’d have to reprogram each time you rotate the tires. Sensor ID ties to the position in the MID, not the position on the vehicle. I don’t know why it doesn’t, since my ‘08 Acura could do it. AnnoyingNot sure this answers the question at all, but Techstream lets you say which position a particular sensor is in when you register them. I can't speak to whether the vehicle dynamically keeps track of the locations.
Not sure if this is still an open question, but the iPhone 12 Pro Max does fit (with the door open) and will charge in the slot. However, I never use that charging slot because an iPhone gets HOT in there.Does the iPhone 12 PRO MAX at 6.7" fit in the iPhone charging tray and charge correctly there?
I measured it only the mini fits in where you can close the door.
Ok, so I think I have this answered. After you rotate on a 2019 you want to re-initialize the tire pressure warning system and then the tires will register in the proper locations.On a 2019, no. Not sure for the models earlier than '16.
Oddly, this seems to be different for different trucks even in the same year. I do a 5 tire rotation every 5000 and I’ve never re-initialized TPMS. I run 5psi over in the tire in the spare position so I always know the sensors updated the positions. I see others have stated they have to re-initialize TPMS on ‘16+ LCs. Don’t know what’s going on there.Ok, so I think I have this answered. After you rotate on a 2019 you want to re-initialize the tire pressure warning system and then the tires will register in the proper locations.
I never re-initialized either. But that's what the books says - wouldn't be the first mistake ever written.Oddly, this seems to be different for different trucks even in the same year. I do a 5 tire rotation every 5000 and I’ve never re-initialized TPMS. I run 5psi over in the tire in the spare position so I always know the sensors updated the positions. I see others have stated they have to re-initialize TPMS on ‘16+ LCs. Don’t know what’s going on there.
I tried that same one, or one a heck of a lot like it and I couldn’t find a way to make it work.Anyone use an anti rattle hitch thingy? I got one like this
Amazon product ASIN B01IO2N44E
but can’t get it below the bottom of the hitch. I have an extender for my bike to clear the tire swing out. It does look a little agricultural though...
Thanks
Thanks
