So about 2 years ago i rebuilt my Odometer and then replaced my Speedometer cable, everything was going great and then one day I heard a loud whining/grinding sound from behind the cluster, and the speedo was bouncing like crazy then it went dead, since then I had the speedo cable tied in an overhand knot around the frame...
Today I took apart my $75 parts cluster as practice... besides the Odometer parts I had previously robbed, this is what I found...
so this was before...
so I knew the spring was all jacked up. but i had questions about some of this stuff, condition wise...
this is a few steps before
here is the needle and its other parts...
my main questions with this are:
if I dig into my good cluster that is in my FJ40 and see anything like this where can I get parts? and does anybody know if that is fixable...?? some of the nylon worm gears in here for the odometer are warn, if my good ones are warn out too can I get parts?? The actual speedo looks pretty simple and other than that one bell ( or whatever you call it) that may be broken, the only issue I see is the spring being all bent up..... Any expert advice here would be apreciated, do I just need to look for another parts speedo or cluster? ?
so that probably means it is an internal speedo issue... the speedo cable shield had a few cuts in the plastic making it not waterproof, but there was still plenty of lube on my cable.... i guess I will still have to pull the "Good" cluster out of my cruier and take it apart to see what the grinding noise was....Grrrr
