- Thread starter
- #421
Hold spring with needle nose pliers. Turn CCW (counterclockwise) as you press in. Once you hear/feel spring click in. Turn CW to sung down. Make sure spring lines-up with center of boot, when you place boot on.
. Since search terms failed for me via mud's search feature and Google, I'm adding some keywords here to make this more searchable:Put new coil boots on (going to post in "When to replace ignition coils" thread too), but could NOT get the new springs to go in, and couldn't find anything on line about getting this style of spring to seat, so put the old spring back in (thankfully pretty easy).
Today I changed the spark plugs out for OEM Denso. I'm not sure if they were ever done before.View attachment 3509585
I noticed there is quite a bit of buildup on the cylinder head. Any suggestion on what to do with that?
Also, some coils are cracked, and some boots are brown vs gray. I read you can get the Denso boot kit. Does anyone have a reference to that?
Would it be ok to put the cracked coils back in for a short period of time to drive for a week or so?
One of mine has been cracked for 2 years now. I swap it from Cylinder 7 to 1. This way it'll be easy to replace it when it goes bad. I keep a spare one in the car.Today I changed the spark plugs out for OEM Denso. I'm not sure if they were ever done before.View attachment 3509585
I toasted a plug and threads are gone. I plan on using a time sert kit to fix. Anybody have a kit # they recommend to use? any tips for using this? I've never done a re-thread.
Did you install new plugs after the compression test? If not, then the torque spec is different, although not listed. I find that I have to use a bit more torque on already crushed plug washers because they've already been deformed. Ideally, they should be replaced. If the plugs were new, then ~18 ft/lbs is a better spec than the factory 13 ft/lbs. It's worked well for me and what appears to be others from this thread.I did a compression check 6 mo. ago and tightened all the plugs to spec. Had an ignition coil fail last week, replaced it, and saw that the spark plug appeared to be under-tightened (not the cause of the coil failure - that was due to age).
Today, I checked all 8, and 3 more were more-or-less finger tight. I tightened all to spec (and a little bit more). I heard no ticking sound, but clearly 4 of my 8 plugs were somewhat loose. Worth checking this from time to time.
