Here are the specifics:
1997 LX450 - Plugs last Changed in Nov 2005 at 108K Miles
Current Mileage is 154K Miles
1FZE engine - Headgasket, valves and injectors done in Nov 2005
SC Added along with Supra Fuel pump in June 2006
Lantank MAF and Snorkel added in 2007. Also Aux tank added in 2007.
I was running stock Plugs. I replaced these today with the Platinum plugs for an MR2 (Cdans recommendation for SC).
I do a mix of driving, some very long trips at high speed. 1-3 times a week lots of city traffic to and from work.
Recently, I was smelling what I guessed was unburnt fuel in the exhaust when I started up. To me that said the plugs were fowl and not burning all the fuel. The results show that likely to be the case. Additionally, my gas mileage has gotten worse over the last few months. Didn't take notes, but I could tell it was trending downward, maybe 20 miles a tank (Just main tank).
After changing the plugs, I could tell it was running a bit different, higher idle like when you unplug the battery, but only slightly higher.
Thought, either I am running rich, or after the plugs deteriorated to the point it couldn't burn all the fuel, the darker covering occurred. Could also be that after the add in of the SC, the stock plug heat range was no longer appropriate.
In case the pictures don't show it well. Main terminal is black, Electrode is dark brown and so is the ceramic around the center terminal.
Doing a google search, this is what comes up
"Can be caused by many different conditions. Carbon deposits build up when the plug fails to fire correctly and burn them off. Air/fuel mixture too rich, choke stuck on, electrical problem, extended periods of low speed driving, plug heat range too cold. All should be investigated"
Everything is running fine with the new plugs, take a while to see if the MPG goes back up. Just thought I would share with some long term data that's much better than seat of the pants info
