Source for 4.3:1 gearset??
mudgudgeon
Resident galah
Touring Flerf
Hi y'all
I'm looking for a set of 4.3:1 diff gears to sit FZJ80 rear diff.
So far no dice.
Anyone know of a source for quality gearsets in this ratio?
I have an OEM e-locked front diff centre that I had built with 4.3:1 gears and solid surface for a 105 series that I'd like to use in my 80, I also have an OEM e-locked rear diff centre that needs a rebuild and re-gear.
A little lower gearing would be nice, but I'd prefer to buy one gearset than two.
4.3:1 gears were standard in 105 series cruisers. Unfortunately the crown and pinion aren't interchangeable from 105 to 80 series rear diff
Tried jmac diff and gear?
Hit up @cruiseroutfit and see if there are any options--but to my knowledge, the 100 series is when the 4.30's came in a 9.5" diff....which will use a different carrier than your 80 series E-locker.
4.30 take-out gears are easy to come by for 100's, if there is some way to make them work....I have a set on my shelf right now, as a matter of fact. :)
