soooooo, can you run different gear ratios on the trail
Discussion in '60-Series Wagons' started by 2badfjs, Jul 12, 2005.
  1. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    after sitting on my r&p gear sets for over a year.
    and getting my front finished on the weekend of the july 4,
    i believe i'm now runnin 5.29's in the rear and 4.88's in the front(will know for sure later when we throw it up on a rack here at work)
    but last night i think i figured the 5.29 are in the rear(could be wrong)
    my question would be;
    if i can run most of a trail in 2wd low,locked in the rear,
    is it possable to use the front axle with a different ratio, ONLY to get thru parts of a trail that need the extra traction?
    OR AM I JUST ASKING FOR TROUBLE!!!
    was planning on a run this weekend :frown:
    thoughts?????????
    thanx,jim :crybaby:
  2. VETTE60
    VETTE60
    1,438
    Media:
    12
    Albums:
    2
    54
    Oct 10, 2004
    Pollock Pines,CA
    NOOOO way.... :eek: you are very liable to break something. i would advise burning the midnight oil and getting it done b4 you go.
  3. nuclearlemon
    nuclearlemon not an addict Moderator
    16,256
    Media:
    87
    Albums:
    4
    1,112
    Jan 30, 2003
    meh-ico, colorado
    i would advise getting it done also, but if you do, don't run ANY traction areas in 4wd...only in soft sand/silt/mud where the r&p has no chance in hell of locking up. or, you could try figuring out which tires you could swap one end to to make them match up.
  4. NocalFJ60
    NocalFJ60
    3,550
    Media:
    6
    Albums:
    1
    6
    Aug 2, 2004
    San Francisco Bay Area
    Jack up the rear or front and check what gears you have in them.
  5. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    Go wheeling, you've got a locker in the rear, right? I bet you can get a LOT of places with a conventional 2WD trucked with a locked rear end. You've certainly got the ground clearance.
    Think of it as a learning experience.. keep it in 2wd low range and see what you can negotiate. I bet you can do a lot more than you realize.
    Don't lock the hubs. Don't even consider 4wd. Theoretically you'll be safe as long as the wheels can slip, but what if you catch a rock or a big root and hook up? Bye bye diffs.... or birfs. Don't tempt fate.
  6. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    my toy tech here is gonna help me figure out what is in what diff.
    i'm gonna try to get another set and slam it out befor i leave on friday.
    CRAP!!!!! i hate doin things twice!!!! :mad:
    i ordered these from DSI on pirate, he has'nt gotten back to me.
    i think i'm screwed, and will have to buy another set.
    both my boxes are the same #
  7. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    you can get away with it, however it is a bad idea.
    do it right..
  8. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    :frown: yeaaaaaaa i know..............
    anyone in denver/castle rock want to help me bang this out thursday night????
    i'll work a deal on a set of sliders for ya!!!!!! 60 or 40's only ;)
    as long as i can get a gear set by then..... :confused:
  9. Mark W
    Mark W
    6,232
    282
    Jan 7, 2005
    The Greatland
    You might be able to get away with in in soft sloppy mud where you are basically hitting it full throttle and spinning all the way through. Otherwise... Nope, no way, not in 4wd.
    But I think that you're getting ahead of yourself. I doubt that anyone could install a set of 4.88s and a set of 5.29s in the same week and not notice the difference. Yo have to grind A LOT more to fit the 5.29s and the pinion is noticable smaller. Betcha a dollar that your ratios are the same.
    Mark...
  10. Mace
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    you are absolutely correct Mark,
    However, if you put the 5.29's in the front you don't have to grind anything..
  11. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    i did the rears one week and the front on the 4th,i didnt put my front drive shaft on untill this last sunday.
    thats when it all came about.
    just got back from having it in the air out in the shop.
    front tires are definitly rotating faster than the rears( in 4low)
    they are definitly different ratios... :confused:
    i only had to grind the rear ring.
    the front i didnt have to pull the center pin.
  12. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    i'm slow with the draw.......
    you beat me to the punch mace ;)
  13. Mark W
    Mark W
    6,232
    282
    Jan 7, 2005
    The Greatland
    If you leave the carrier assembled and the pinion shaft in place, then you can put 5.29s in without grinding the gear. But you then have to grind the pinions shaft (ends) flush with the carrier. Hard to forget doing that.
    And if the front is turning faster than the rear then you don't have 5.29s in the front and 4.88s in the rear.
    Mark...
  14. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    right, it would be the other way around.
