SOLVED: Bad steering wheel and body vibration
Kansas City
Backstory
I installed new 35x12.5r17 Kenda Klever MTs back at the beginning of 2015 at around 360k miles and they were balanced with airsoft BBs. Just before this, I installed Nitro 4.88 gears along with full axle rebuilds front and rear. The new Kendas rode pretty well and were smoother than the BFG KM2s that came off of it. Previously, I had a set of BFG KM1s that I had purchased used. They had some slightly abnormal wear and thus always had a slight vibration. So really for as long as I can remember, my Cruiser has had a slight vibration. What's weird is that the vibrations seem to almost disappear when I have a large tailwind.
Fast forward to Spring of 2016...I found some dangerous cracks forming between the tread lugs on my tires. This was less than a week away from leaving for a 3000 mile trip to Moab and Colorado. When they replaced my tires under warranty, I had the shop leave the bead unset so I could add BBs to balance the tires. The new set really shook the cruiser around, and both body shake and steering wheel shake were slightly present around 55mph and brutal around 75mph. Due to the Kendas still being a fairly new tire, I chalked it up to being a more out of round batch tire. My dad and I decided to add more BBs. Going from the previously successful 8oz to 16oz, we did not notice a gain.
Over the past year I have chased down this mysterious vibration. Currently I have 396k miles.
My rear output bearing on the transfer case had slight play in it. It was also slightly leaky. We replaced this and did not notice a reduction in vibration.
After returning from my 2017 Spring Break, my dad helped me watch the cruiser from another vehicle on the highway and looked for a potentially bad tire/wheel combo.
Noticeably worse than the rest, the passenger rear tire was really vibrating. The passenger front tire was smooth so we started by swapping the tires. No luck
Next we checked all the pressures. All good there. I also experimented with different pressures with no success.
We swapped the rear shocks side to side hoping that maybe one of them was not providing enough damping. Not much luck there.
Deflated the residual air pressure in my rear air bags. Helped just slightly.
Checked the wheel bearings. All good there.
Then we drooped the rear axle with the tires off the ground and put a prybar between the lower RCA mount on the frame and the arm. Sure enough it had some play that would wiggle the rear axle. A lot of the bushings had deep cracking evident, and while some looked better than others, I'm glad we changed them all out. The panhard bar seemed to have the best surviving bushings. After this, we replaced the upper and lower control arm bushings along with the panhard bushings. Here is where the photos of the bushings can be seen if anyone is curious what 400k miles does to them.
The shaking still existed.
Next up was a set of OME sport series L shocks and a matching set up front. The ride tightened up, but the shake still existed. I had also put on a new OME steering stabilizer to no avail.
I have also torn into the front hubs several times after checking bearing preload and retorqued them. New slotted FZJ80 sized front brake rotors and calipers also went on which would eliminate a heavily warped rotor. None of this ever seemed to fix the bigger issue.
My steering box is also questionable. I have a rebuild kit for it as it used to leak at what seemed like higher altitudes, but stop leak has stopped that and it hasn't dripped a drop in months (except where it was dripping some drops on Poison Spider on Moab, but it hasn't leaked since coming down in elevation...weird I know)
That pretty much contains about everything I had done up until May 2017. Since a bad mtb wreck, I haven't been able to do much work, but I have been learning about various vibration causes and symptoms. Deep down I thought the shake could be a driveline vibration, but at the same time, this is a very harsh body shake as well as steering wheel shake.
I found this great 1990's Toyota video on Youtube addressing NVH (Noise, Vibration, and harshness) that explains how to calculate the different kind of frequencies found among different vibrations ie driveline, vs tire and axle shaft vibrations. This convinced me I did not have an issue with either driveshaft as my vibration is closer to 15Hz.
I also learned about the run out of the wheel and tire, and how you can phase the two to help with vibrations. The person who bought my 17" FJ Cruiser steelies said "I am buying these to replace the 8 spoke wheels as they never seem to balance out". So ever so slightly I thought it may be the phasing of the tire and wheel as my previous set had been fine.
After a lot more thinking, I decided to set up an appointment to have a new set of 315/70/17 BFG KO2s installed so I could rule out or confirm that the shake was coming from the tires. The local 4wheelparts was advertising a set of 4 for $689 installed. Unfortunately, after speaking on the phone, the employee said this deal only applied to C rated tires which their ad said nothing about.
Then I decided to mount my GoPro in various places underneath to watch the axles, tires, driveshafts, etc while running some highway sections. This ended up being a huge waste of time.
Yesterday, I went home for some medical appointments, and my dad and I checked the tie rods and all front end components only to learn that nothing had changed. The only remaining thought is a possibly worn steering box as it does have 400k miles on it, but my steering still feels pretty tight and responsive.
At this point I figured I would go to the local tire shop and see if they would run a wheel/tire combo and see if it balances out with the BBs. They were not going to do that, since the owner didn't believe in balancing BBs. I also mentioned checking the run out of the wheel and tire, and putting them in phase, but they had never heard of anyone doing that. He suggested just ditching the BBs and balancing them.
Anyways, after all of the thinking and work that went into trying to find this shake, removal of the BBs and a $90 balance job did the trick. It is almost funny how simple of a fix this was and the amount of miles I have endured this annoying and at times scary vibration. After this ordeal I think BBs can work, but it really depends on the tire. My brother has 35" Mastercraft MTs and it stays pretty smooth. Now mine is smooth until 85mph which is as fast as I could get it up to.
I can't remember where I saw it, but there's a magic balancer on the market that does exactly that. I wouldn't trust my life to it, but it's fun to watch on a bench.
This is the first I've heard of BB's not working. How many ounces did you put in each tire? @SUMMIT CRUISERS Jr
8oz originally like my previous set had in them. When that didn't help, we doubled it and did 16oz. That didn't help much but maybe a little bit. That's how it's been for the past year.
I've also experienced BBs not working. I installed the exact recommended Dynabead BB weight for my tyres and the vibrations were awful. Always started between 50-70mph. They also seemed to go in and out of phase in that they could be running smooth one minute and then the vibration would just start with no change in speed or road surface. Dynabead advised that I could also use balancing weights with the BBs which I did as I was half way across Europe on a trip and didn't want to try and explain removing the tyres and beads with no native language! This resulted in only a partial resolution - the vibration is less but still present. I intend to ditch the BBs completely as I now believe them to likely be the cause of the issue.
Have you ever run the tires that appear to have be balanced by BBs without the BBs?
I doubt BBs work, ever. If the tire carcass is out of round, the BBs will just go to the point furthest from the center as the wheel spins.
Good to hear a traditional balance job did the trick! It sometimes takes a lot of weights in the right place(s) to balance these big tires.
Exactly. Sometimes it would stay pretty smooth but still had a slight vibration. Then maybe a bump in the road would unsettle them or just a slight increase or decrease in speed and the vibration would dramatically increase. More often than not the vibration was very much so present.
I have not. Now that you say that I would have been curious as to how my previous set of Kendas would have been without the BBs.
These tires did take quite a bit to balance out. Looking at this pic with weights in varying places, I have a hard time believing the BBs would have gotten to and stayed where they needed to be to balance these tires.
Yep, same here. Because my tyres had balancing weights added with the BBs in situ I was able to observe the tyres becoming unsettled during the balancing. One minute the tyre was balanced and the next it was not. The guy doing the balancing said it was impossible to properly balance them as every time he thought he had it right, the imbalanced area would shift. I watched him repeatedly try, shake his head and keep adding more balancing weights to no avail. I've put up with them like this for a while - I'll now be sorting it this week and removing the BBs entirely.
You think those stick ons will stay?
I'm hoping so. I'm also taking notes of what's on each wheel in case the vibrations start back up. Then it shouldn't be too difficult to get them to balance out again.
Hopefully removing them solves your vibrations completely. I haven't been this happy with a "mod/fix" on my cruiser in quite awhile.
Looks about what it took to balance the Geolanders on my Tundra.
It's amazing how good it feels to get rid of the vibrations.
Yeah it's such a more pleasant and controlled driving experience. I'd love to just get in and drive. Ironically the vibrations typically kept me from pushing the speed above 70 mph. Now that my tires are smooth to 85, I'm going to be wanting to replace the 3FE now that it's comfortable at higher speeds haha
Even with smooth rolling wheels/tires, I only drive slow roads with the 3FE. That way I don't know what I'm missing.
But, I'd love to try a 3FE with an H55. I don't have to do a smog check again in this county...
To stay on topic: check the axial and radial run out on your wheels first when trying to track down vibrations when driving. Otherwise, all other efforts will be in vain.
Wow the Kenda took THAT much weight to balance??? That's crazy! No way BB will help in that case, they are only good for high speed and the tires are slightly off because you can't get all 16 OZ of loose BBs to stay in that position!
Just curious on why you want to go with the BB route instead of tire shop balancing them?
The reason race cars don't use wheel weight is regulation because at super high speed the wheel weights are very deadly projectiles. plus their tires are super light and near perfect to begin with so it only take a little bit of mercury in 40,000 dollar wheels to keep thing perfectly balanced at 200mph. Not quite the use case we have here.
It had worked for me before so I figured I would continue using them. BBs seem to make sense on an off road vehicle where the weights could be knocked off. To me it seems like the BBs would always balance out whatever changes might be occuring to the tires such as holding onto mud and rocks. It worked for my KM2's and relatively well for my first set of Kendas. Then having the tires replaced under warranty a couple days before leaving for a huge trip just kind of rushed it and having the shop balance them didn't even cross my mind since of my experiences using BBs.
Strangely, the night before I took my tires in to be balanced I had a dream that I had taken them in and paid money to have them balanced. Only this time they hung the wheel from the ceiling and looked for it to be parallel to the ground like a tire swing.
So, a good balance job solved vibration issues, who would have thunk!:hillbilly:
... BBs seem to make sense on an off road vehicle where the weights could be knocked off. To me it seems like the BBs would always balance out whatever changes might be occuring to the tires such as holding onto mud and rocks. ...
Kinda, maybe, works well on narrow tires. But, can't correct for axial balance problems that are more common on larger/wider off road type tires. Big tires, abused on the trail, will always need more attention to balance.
...Strangely, the night before I took my tires in to be balanced I had a dream that I had taken them in and paid money to have them balanced. Only this time they hung the wheel from the ceiling and looked for it to be parallel to the ground like a tire swing.
That is called static balance, old school, on skinny tires it kinda works.
I had a leak in one of my KO2s. Took it in and had it repaired and had them rotate and balance them. I was shocked by how much weight they had to add to make the one balance. This is the tire that had to be repaired. All of the other wheels have 1 or 2 1" weights on them.
I have always requested sticker weights in my off road vehicles. The traditional balance weights get knocked off on the trail.
Recently I removed the sticker weights from all of my wheels and they were not easy to scrape off. And once I did get them off, even acetone was unable to completely remove the left over glue and paper backing.
Sticker weights all the way.... Having said that, I have gone to a set if 37" Trxus and had discount tire put 10ounces if dynabeads in each tire. I have yet to run the tires due to my 80 being down for other reasons. A couple of other members have had good Luck balancing the trxus so my fingers are crossed.
If all else fails , try a Road Balance at Camelback?
