NM Frontier
- Thread starter
- #261
Got the rest of the pyro install done today, boy drilling in to the down pipe/elbow manifold defiantly ranks up there with snorkel install nervousness. I ended up pulling the elbow off the back of the turbo and putting it in the vice so I could drill and tap the flat spot on it. You could almost do it with out taking it off but tapping it would be a real chore. Over all it went smooth no busted studs pulling the elbow and the hole tapped nice and straight.
Hole drilled ready to tap the 1/4 NPT threads.
Starting the threads, still wondering what I'v done...
Fitting in and starting to feel good with the decision to do this.
Thermocoupler in and setting the depth to the center of the down pipe elbow.
All put back together with the modified heat shield to clear the thermocoupler.
I still need to get the proper union for the tubing coming off the boost part of the gauge to tie in to the vacuum hose to the boost tee. I got a few I thought would work but I cam up with a cleaner way this afternoon and ordered a new one. But Ill get it out tomorrow for a test drive and at least be able to see what kind of EGTs I'm getting.
Just need to clean up a few loose ends and this will be wrapped up!
