So I went to look at this cruiser yesterday ('97 40th). The Interior was in the nicest shape of any I have seen yet, the exterior pretty good, though far from perfect. Drove well, except for the brakes, Lockers engaged instantly, low range engaged easily, fluids looked/smelled normal, mileage was low (under 80K). Couldn't find any signs of a HG leak. Here are the glaring issues for me..
~> Axel seals failed, gray grease ozing from the swivel balls
~> Brake pedal goes to the floor before anything happens. He said he just replaced the front pads recently, and the rotors about a year ago. Brakes may just need to be bled, but could it be an issue with the master cylinder?
~> Windsheild had a crack. Small, but won't pass inspection in my state
~> Ticking sound at idle (normal?)
~> Sounded like a vacum leak when accelerating
~> Transmission and transfer case showed some minor leaks
~> Fair amount of corrosion on the undercarriage
~> Fair amount of Corrosion on the wheels.
I figured up in my head probably about $2,000 in work right after I get it to take care of the axel seals/Brakes/Windsheild and clean up some of the corrosion before it takes hold.
Any thoughts from the group on what this truck should be worth, given what needs to be repaired? I made him an offer based on what I thought was fair market value for the truck if I had had to do nothing to it, minus the $2k I felt I'd need to spend on it. Opinions welcome..
