ToyotaDon
I am here
So I replaced this water pump the other day, and it was just sitting there on my bench.
I've used the aluminum from water pumps before for little projects, one of them was replacement swing arms for my sons' toy quads. Anyways, I was looking at this nice straight section of the pump which also had something intriguing on the other side.
I know, it's just a Toyota casting mark, but you can see I was starting to draw some lines, because I had an idea.
There wasn't much wrenching going on in the shop today, so I pulled out a few tools and went to work with this piece of metal.
First, the rest of the lines that were drawn...
Aah, now you're seeing what I'm seeing.
What do you do when you don't have a band saw, you start with a reciprocating saw. When that doesn't seem very efficient, break out the cutoff wheel, so that's exactly what I used to rough this thing out.
Spent some time with the orbital sander.
No Dremel, so I used the next best things, die grinder with this bit (sorry for the out-of-focus).
A little work with a "square" file.
Drilled some holes and kept sanding with increasing grit sizes.
I think the finest I used was 400 grit, then followed with some aluminum polish and a rag. I could probably make it shine more if I used a buffer, but I think it looks pretty good for being made "by hand."
Now the question that everyone asks is, "What are you going to do with it?"
So, any suggestions???
