- Thread starter
- #61
Thanks Todd - I'm running a 50mm OME lift. Just went out and jacked it level to measure. Measured from the inside edge of the wheel to an edge on the bump stop brackets (and verified to another spot on the frame). It looks like only 3 to 4 mm offset. That's something I guess - every bit counts. But you won't get that much back at the pan, so not sure the adjustable panhard is worthwhile.
So what does the double cardan gain you on the shaft? Was that for the transmission clearance problem, or to address other driveline issues? I haven't had any vibration issues with the stock shaft.
My stripped nut is actually on the flange, not the frame. So easier to deal with. Considering drilling it out and tapping for the next size bolt - but there may not be enough of that nut left. I suppose I could grind it off and tack a new nut on there, but it'd be a PITA to get to. Simplest would be to simply run a longer bolt through and put a heavy washer & nut on top of it.
It's Alive
