orangefj45
Supporting Vendor
argh. That's not "good news".
Ouch!Really deep grooves in the harmonic balancer.
Just talked with Georg and those input gears won't work for the 1 piece TC since they are too large to fit through the PTO window. Only solution is new tail shaft and gear.Possible solution:
@orangefj45 sells a modified Terrain Tamer TC input gear with a longer contact area to engage the unworn area of the shaft. It doesn't state that it fits the 40 series, however. Anyone have experience with this part?
Sounds like money well spent on 2 new parts.I just got done making the same assessment for @HKforte. All it took was this: put worn input gear on unworn section of tailshaft to determine how worn the input gear was. Take new input gear and put it on worn tailshaft to determine how much backlash noise you were going to hear under your seat every time you went from drive to coast and back again.
He had me replace both.
The truly sad part was that the input gear didn’t have a lot of miles on it; it was an Orion with maybe only 10k on it. But the previous rebuilder did not think the tailshaft needed to be replaced.
