Call's himself a Knight of the Iron Pig's yet is that a Saginaw PS pump I see???
Not Armstrong Steering????? Cushy...any sales at Pier 1?
What are these "special vacuum lines" and "computer boxes" you speak of Pighead? The Arakawa plant must have forgotten to put those under the hood of my 60.
On the other hand, I have thought a hi-lift mount that slides into the reciever hitch might be nice. It would have to be up where it wouldn't drag offroad, but yet be out of the way of the tailgate. Of course that would put it right where I could smack my kneecap on it.
I got this from old school desert racers who used this trick to keep air filter wingnuts from vibrating loose.This isn't a hi-lift, but it's applicable to any bumper/rack. Just some tabs welded on my ladder that'll hold the lift.
I'm actually just figuring out mounting hardware now. I'm thinking 1/2 inch standard hex bolts with some metal washers and rubber washers, with wing nuts to hold them on. I can just copper wire them in place, or double nut them. Thoughts on hardware solution?
Edit - I meant it's not an ARB.
Securing wingnuts there is simple. Tighten them to where you want them to be, then mark the ear of each nut that is closest to the other nut. Drill a small hole in those ears and hook a spring between them.
Secruing wingnuts there is simple. Tighten them to where you want them to be, then mark the ear of each nut that is closest to the other nut. Drill a small hole in those ears and hook a spring between them.
Those clamp-on mounts shown way back yonder early in the thread look to be from Fourtreks.com
I got tired of carrying my HL and it is now a driveway ornament. I carry this instead:
