Your clutch fork might not be moving far enough to get it in gear. Does it shift with the truck off?
Hope today is better.
Damn Brian, sounds like a s***ty day indeed...
And such a shame with the Benz. That's one nice example of a TD wagon, and it sounded great just a few weeks ago!
Here's to hoping you have better luck with Tofu..![]()
Did the shifter go back in with the selector fork misaligned??? Hard to tell with the tranny cover (not to ...
Tranny resolution, in all likelihood:
I had put it in gear to make phasing the rear drivshaft easier and then took the shiftter out. It wasn't in N.
All I have to do is remove the shifter and use a screwdriver to pop it back into N, and reinstall the shifter.
Had I had food in my stomach, a little daylight left, and a few minutes to calm down, this night could have gone very differently. But, someone would have bought that MB from Dennis (his plan was to eBay it), the rod would have gone on them instead of me, and they'd be gunning for my hide or Dennis'...
So, this is a better turn of events.
So, FL Cruiser, what's up with your brother's bad experience with his Taiwanese 2H rebuild kit?? David was perplexed when I asked about this issue.
He doesn't remember which supplier he purchased the kit from. I think they came from California.
1st issue was the gaskets were very cheap. Kind of cardboard like. Head gasket didn't look like they would seal all the passages. He tossed them and bought Toyota gaskets.
2nd issue was that no machine shop in the country (Costa Rica) wanted to press in the pre finished cylinder liners. They all wanted to press in unfinished liners, then bore and size after they are in the block. So he ended up buying new unfinished liners.
3rd issue was just the fact that the pistons were made in Taiwan. In North America we get the “better” Taiwan and Chinese parts. In other areas of the world they get the worst of China and Taiwan. Just the fact the pistons had “made in Taiwan” stamped on them he felt he got ripped off. I personally don’t think the pistons being from Taiwan is that big of an issue since they looked all right.
The kits didn’t end up being that much of a bargain after purchasing new gaskets and liners.
On one of the H powered farm trucks he cheeped out and used the liners that came with the kit against the machine shops recommendations. The truck smokes and uses oil. Don’t know if it’s the result of using the liners or not. I do know that prefinnished liners get used in lots of diesels. Don’t quite know what to think of that.
tofu has left the shop. It has made the 1 hr trek north to its home and all went well. Good luck and enjoy your rig .
62 dash? Maybe easier to screw in some 3FE senders?Gotta swap back the HJ gauges because the coolant temp and the oil pressure guages were way off.
