- Joined
- Oct 9, 2006
- Threads
- 122
- Messages
- 2,824
- Thread starter
- #201
Give me two weeks, mi hermano de Panama'.
Parts ordered:
* Two oil filers and one fuel filter, for 2H (4WheelAuto - ~$65)
* Chromeless windshield gasket ($OR -$69.95)
* New speedo cable ($OR - 91.05)
Soon 2 B ordered (all from Cruiser Outfitters):
* Knuckle rebuild kit - $87
* Inner axle seals (front, two) - $2.50 (each)
* Hub rebuild kit (or does it come in the knuckle kit?) - ?
* Front wheel bearing kit - $45
* Right rear lens --$15
* Split transfercase rebuild kit (again) - ?
As usual, I am indebted to fellow Landcruiser fans in ways I know I'll never fully be able to repay. Fortunately, Turnmeover (D) has had the time, patience and knowledge to get this project back in high gear. In the two Saturdays and a half-Sunday we've wrenched, the progress has been impressive. Having the wiring 95% done is a real motivator...
On the list remains the following jobs (though I am sure I'll leave many things out), in roughly this order:
*complete the back-up light and tach wiring. (D) DONE
*trim and loom the harness so it looks nice and purdy.(D) DONE
*complete the clutch lines and mount the slave line stop to the firewall. (B&D) DONE
*replace the fuel injection pump diaphragm and gasket. (B)
*swap out (?) the key cylinder/ignition glow module (D) and eventually rekey the whole vehicle). DONE
*replace the twin side cover gaskets.(B)
*cap the fuel tank pick-up unit return nipple (unit from an FJ60 - no return necessary in the diesel) and cap the fuel breather loop return nipple. (B) DONE
*fill up with B100. (some bitch) DONE
*refill coolant, clutch fluid. (B) DONE
*modify indicator light panels for glow, filter and ?, and reinstall instrument cluster and a/c, switch and ashtray console. (B)
*see if the idler shaft can be pushed back into the transfercase (it is out about 1/8")and lock-tite the idler shaft tab bolt so that this thing does NOT back out again. (B) DONE
*if not, rebuild transfer case again (yay!) (Mel Lowe, D&B)
*reinstall console, seats, flooring, etc. (B)
*service/rebuild the knuckles, inner axle seals and hubs (oily leak running down one of the tires from the hub), as needed. (B&D)
*rig up a second battery tray, ground and lead. (D) NOT DOING DONE
*inspect brakes, replace as necessary. (B&D)
*obtain exhaust flange lead gasket, reinstall the exhaust downpipe, have remainder of exhaust bent up and installed, with hangers. (B)
*install Sheila's windshiled in a new chromeless weatherstrip. (Mauldin's Auto Glass)
*have a new a/c hose made using two exisiting hoses, convert the a/c system and refill with refrigerant. (?)
*repair rear tail lens and metal from when we smashed the asses of Tofu and the 40 together(!). (?)
*respray entire vehicle and pressure steam clean seats, door panels and headliner. (?)
*fab a new front bumper (D&B) or get Tofu's bumper back from Mel Lowe...
What am I missing???![]()
TOFUDEBEEST HAS MOVED UNDER HER OWN POWER. The first tine in a year she has started.
WE got a lot done saturday . We should be done by the 2nd week in october then Tofu goes home.
Hey it is all for the love of cruisers. And it was worth it to meet some other cruiser heads and get a look see at there nice rigs.
Winch? SOA?
You plan on wheeling this rig?
FYI the springs we pulled from Shelia weren't manufactured by ome.
They look real beefy and I would be proud to have them, but they are not OME.
Post a pic of them, so others can verify.
If you do decide to go soa, I'll take those lift springs off your hands.
Wheeling, yes, but nothing that will crunch body panels, so no alpha or beta. Mild wheeling, nothing off camber. I don't want to budget for longfields or anything else to really build up this rig. I will get some rear lockers however (prolly Aussie), no matter where I plan to go. I got stuck once in mud after bragging about how unstoppable cruisers are. I would not have if I had been locked... Definitely not the mall cruiser you built; not one part got painted before going back in.![]()
Yeah it was a welcome distraction and we met waht appears to be a good new addition to NFC.
Dennis, You rock man. I thank you so much for this amazing help.
NOTE to all: due to a missing dot in a wiring diagram, which if there would have indicated a postive connection to the EDIC motor or relay, we spent at least three hours last night starting and restarting this 2H which would either not start or would stop as soon as I released the key. Dennis got frustrated, but kept his cool and persisted. In the end, I took a leap of faith as he wired this up as his gut told him and it worked... (correct this if I got the details wrong, dude).
FL now officially has a Cruiser wiring guru (particularly diesel).
So with that being said. Tofu will see dirt roads and pavement.
If your hoping lockers will solve your mud problem, think again... Just makes it so you get farther in before you get stuck! Especially in FLBut at least you get goo thrown up on both sides of the rig. glad to hear it's up and running. KB awaits.....
