You're more than welcome, and thank you for saying so. I try to give useful info, and will answer any question to the best of my ability. Mud has been and is to this day so helpful to me, I'm just paying back/forward!Very good info in this thread. Thanks!
My pleasure.Yes, as @Rigger said, great info and dialogue. Thanks for posting this up!
I'm curious how you got grease into the rear U-joint on the front driveshaft, the one by the output for the transfer case. The crossmember is really in the way. I tried a couple of different types of gun fittings, one on a stiff "pipe" and the other on a flexible hose. No dice. I had the truck up on stands so I was able to spin the shaft into any orientation, but I was unable to get the gun fitting on the zerk no matter what angle I tried.
I bought one of those "needle" type adapter fittings the other day, I'm gonna give it another go when my Amsoil shows up and I can do the diffs.
I'm also nervous about pumping any more grease into the slip joint zerks for both shafts, I'm not getting any extension action, and I've put probably 20-25 pumps into each joint.
My pleasure.
Check this out, I just realized something.
I updated post #2 with pic of door plate showing 10/11 (Oct 2011) and update tile:
I'm looking in the FSM this morning and I just notice reference to some components a MFD of 08/11 - forward. The TIS shows 08/10 - 01/2012 (normally 200 series starts/ends in August) range for 2011. It then breaks the year up in some components to 08/10 -08/11 then adds the additional MFD date 08/11- forward. This is the missing 2012. The next entry is 2013 which has MFD date of 01/12-08/13 (normally MFD start would be Aug 2012)
Wow I've got a 2012
The head on my flexible line coming off my grease gun has an OD of 13.65mm. I had all four on the ground to keep sleeve yoke in a neutral position. I had the zerk of the sleeve yoke pointed down, to get it first. Then I move the vehicle until zeak was face in towards the center of vehicle. I was going to pull heat shield as I'd done on @Emcd LX when I lube it. But I decided to wipe of grim from zerks and give a try without removing shielding or move vehicle again. It didn't look like I could, but sure enough I was able to get fitting of grease gun on the zerk. It was a very tight fit, but I caught the zerk in the blind. I was not sure I was on the zerk, until I saw grease follow from the universal seals.Same question here. I have a needle-type fitting but haven't tried it yet.
Thank you for say that.As many of your threads tend to be, this one is no exception, and is sure to be pegged as a go to reference thread.
Your statement of born on date got me thinking to check mine. 12/11! Cool Info.
The 2012 has been found. Now if I could get title to agree!I always put a can of 44K in the gas tank on every rig I own. Could be snake oil, but I've been drinking the kool aid for years, as have most of the Toyota Dealer shop in Colorado.
Another first step is checking vacuum lines. Love it! It's first time all are looking very good.
Air filter replacement and air box cleaning was needed as usual.
View attachment 1800548 View attachment 1800547 View attachment 1800549
~5 minutes more or less at around 4,500 to 4,800 RPM. I'll then shift back to "D" and let it cool down for ~5 minutes or more than do it again. I generally drive with a lite foot. But every so often I'll really stomp on the gas. This also is to blow out the carbon.How long do you do your high rpm burn off for?
Thanks!Great thread!
thank you for saying so. Glade it's helpful.Great post... As a new(to me) 200 owner I'm using your post as a guide to go through my vehicle. I'm new to this platform but not to wrenching. I am working at a much slower rate than you...
I'm glad you're enjoying!Enjoyed reading your posts. I've finally found my 08 LC that came with some underbody rust - something I tried so hard avoid based on my previous experience with my FJ Cruiser. I nevertheless purchased mine because there were so few out there, especially one that was within driving distance in So Cal. I'd love to own an LC 200 that look half as lovely as yours underneath. And so I've been spending hours grinding off the excess rust, washing, priming, and painting, etc.
