Cool, we'll holla..Part# DIFF36149 @ Cruiser Outfitters![]()
While I'm waiting for the rest of the parts to arrive to overhaul my cooling system, I decided to tackle some smaller tasks today since an order from my local dealer showed up. BTW, with Toyota's new dealer parts websites, I love the fact I can order stuff from my local dealer and pick up with no shipping fees instead of having to order from McGeorge or the like.
New liftgate struts (to replace the 2x4), shift knob, and pedal pads. Some items that make the day to day driving experience better.
View attachment 2860953View attachment 2860954
Then thew in my new Koito Toyota headlights for $40.14. (PN: 81110-60P70)
New on the left, old on the right.
Then while putting in the new harness, I decided to get rid of some of the old accessory wiring in the truck that I didn't need and/or will replace with other accessories and newer wiring. Still more to come out.
Hey Hokie, my extended end links and sway bar bushings look to be in the same shape yours used to be. I searched on Cruiser Outfitter and couldn't find them. Do you have a SKU or part number?Got her back together after some family time this past week. Now I'm chasing coolant leaks from the new hoses, some causing small puddles on the ground but only after/while driving. Seems to be some leakage from the WP after torquing it to spec and some from the various oil cooler lines. The clamps are almost maxed out so I will have to look into that further this week. New hood liner is looking fresh!
While I was in there, I put in a 3FE fan clutch.
I also sanded down and repainted the fan shroud and the upper air cleaner.
I also added some new extended end links and fresh sway bar bushings since the stock ones were toast! Got them from Cruiser Outfitters.
With the new power steering pump, I threw in a Magnefine filter per @HemiAlex recommendation.
You can still throw in that choke shaft we fixed/modified right?
Do you have a new insulator? Iirc the insulator has bonded gaskets, meaning you don't need additional ones.
After my lift on Falcor I put in 4 degree shims and it made a world of difference. No more random wandering on slightly tracked freeway sections, return to center felt better and virtually zero bump steer. I really like the ones that Valley Hybrids offers, they're super high quality.
Good feedback. I'm definitely wanting the steel shims. I'll see if I can get some ordered and installed prior to GSMTR.
What is the advantage of 4* vs 2* shims. Is more always better?
