For Sale San Francisco: 1984 FJ60 Land Cruiser
1984 Toyota Landcruiser FJ60 4.2L 2B carb
mileage: 314,8xx
title: Revived Salvaged Vehicle Title (see below)
carb/cylinders/valves: rebuilt/refurb 9/2015 @ ±300,039mi.
transmission: 4 speed manual: original
suspension: original
clutch: replaced 10/4/2017
tires: (4) LT235/75R15/C 104/101R Mesa A/P2 Owl tires: 4/2018
audio: Kenwood #KRC-740 FM/AM cassette Stereo (w/ manual copy): 11/2004
smogged: 8/25/19
I have owned this Bay Area work-horse since April 22, 1999 and I am the 3rd owner. I bought it with salvaged title (See #2 below regarding title) with 169,012 miles on odometer. I have used it as my daily driver during the last 20 years (average mileage comes to (7291.5 miles/year).
For regular maintenance/basic repairs it has been primarily cared for by Waylon @ Toy Shop, and Hans @ Hans Art. Gary @ Mudrak has overseen more intensive care issues such as front end rebuild, carb rebuild, and cylinder valve job., clutch replacement, and as source for body parts.
Truck comes with original owner’s manual and service records (including some from previous owner) July 1996 to August 2019.
Asking price is based on two factors:
#1 There is outer roof rust along the roof rain gutters, front passenger front door edge, and top of windshield pillars. For the last 2 years I have arrested rust, primed, and sealed tight with 3” Gorilla tape (change out every 6 months) and no interior leaks have ever occurred. There are some very minor body dings but otherwise the body and frame/underside are in very good rust-free condition.
#2 on May 2 2018 I was hit by a jetlagged tourist in San Francisco who took out original hood, passenger side fender, head/turn signal light bucket and lens, running lights, front bumper & front grille. My lousy insurance would not pay for body shop repair. I have since sourced and replaced all damaged body and accessory parts from Mudrak and put everything back together. It drives totally straight and has no known frame damage. I have had it aligned, Brake and Light Safety Inspected, passed CHP Certificate of Inspection (CHP 97C), and re-registered it with new plates as a “Revived Salvaged Vehicle Title” . I continue to drive it daily, albeit with a 3-tone paint scheme.
Asking $7000 obo REDUCED PRICE on 9/9/19 to $4750 (not interested in trade)
DATE & MAINTENANCE
8/30/19 passed CA smog,
8/26/19 replaced EGR “L” pipe gasket
5/24/19 adjusted passenger side front fender/door/hood
5/1/19 passed CA smog, replaced ERG valve, cleaned horn contacts
8/28/18 new air pump
8/24/18 brake & lamp safety inspection w/ certificate, new 2 rear drums & shoes, new right front running & dash light bulbs, fluids check & fill-up
5/31/18 alignment
5/19/18 replaced hood, passenger side fender, passenger side head light bucket, passenger side turn signal lens, 2 front running lights, front bumper, front grille
4/13/18 4 new tires (Mesa AP2/Owl) & alignment
4/12/18 new ignition wires
10/4/17 smog, new clutch, flywheel, clutch pin
4/8/16 new (remanuf.) starter
1/12/16 new radiator
9/26/15 rebuild front axle, tie rod ends, re-build carb, cylinder head & valves refurb, new front heater core, AC refurb (mileage on 10/16/15 smog check =300,039)
7/10/13 replaced air bypass valve
6/13/13 replaced fuel tank filler neck
12/7/12 new air pump & belt, brake master cylinder, booster, rear drums and cylinders
1/18/12 new tie rods ends/kit, stabilizer, power steering pump/belt, radiator hose kits power steering belt, heat riser gasket
9/28/10 new rear brake drums
4/19/10 new catalytic converter
1/2/08 new clutch master and slave cylinders
11/27/07 replace alternator with Toyota re-manufactured
7/30/05 new catalytic converter
5/27/05 new rear signal housing and lenses, rear quarter window glass, housing, complete new paint to match original tan (464) , new gas cap
5/6/05 replaced rear window broken, rear bumper and rear marker, & gas cap
12/17/04 replace clutch
11/20/04 replaced radio an installed 2 ea. front and rear new speakers
7/9/04 replaced dashboard , dash switch bezel, and 2 front seats
11/19/03 new fuel pump, new windshield
4/3/03 new catalytic converter, power steering pump
12/10/01 replace front left and right door lock cylinders
11/7/00 replace rear tailgate, rear signal lens rear bumper & bumper bracket
I am not attempting to be snarky, but are you serious at $7,000 or was that a typo? I wish you the best of luck, but seriously,
a salvage title....accident damage (not repainted).....cracked dash....ridiculous roof rust...ridiculous door rust....dirty"ish" interior and so on. Wow my head is spinning.
I was interested at first, until I saw the rust vs $$$$
A person would spend the sales price on body work/rust repair alone.
Good luck
I appreciate the feedback, I did do research on regional $$ prior to listing but obviously missed the mark. Will re-evaluate and once I find a vacuum valve will update.
REVISED PRICE $4750 cash no trade
vacuum valve fixed and line replaced, starts and runs well
including under photos
