Code | Name | Price | |
Turbine Housing Clamps and Bolt Kit, Hardware to fasten CHRA to Turbine Housing - YES | $19.95 | | |
Steel - T3 5 bolt Discharge External WG - Weld On 3" JS Series - NO | $28.00 | | |
Stainless - T3 5 Bolt Discharge External WG - Weld On 3" JS Series - NO | $39.00 | | |
Ultimate Internal wastegate valve for T3 5Bolt, high flow 3" V-band Style, REV 2 STAINLESS CAST BODY - YES?? not sure about the V-band | $168.00 | | |
Gasket, T3 Turbine Inlet - UNDIVIDED - YES | $6.95 | | |
Stainless Steel - T3 Inlet Weld Flange - NO | $39.00 | | |
Mild Steel - T3 Inlet Weld Flange - NO | $23.00 | |
Where did you buy from?My gtx3582r will be here on Thursday![]()
Looks like thrust bearing failure, which led to air seal failure then main bearing failure. Yup, toast
You mean blow off valve? NoDoes that safari set-up have a compressor bypass valve? If not it may be the root cause of the thrust bearing failure.
Similar but different. Blow off valve wastes compressed air overboard. Bypass redirects the air back to the intake side of turbo. It keeps the turbo spinning between gear changes so you don’t loose wheel inertia and also prevents thrust loading on the thrust washer, as does the blow off valve. But why waste already compressed air overboard?You mean blow off valve? No
I am still worried that there was a lot of heat going on. The question in my mind is whether there is damage to the engine.
