I got this...
RS3000 Toyota Vehicle Intrusion Protection
and it said this "The RS3000 ECU can be programmed to be operated by as many as 4 remote controls. Additionally, the provided remote controls top and bottom buttons may be assigned to operate another 1998 or 1999 model vehicles RS3000 security system, and both buttons can be programmed to operate the system in one vehicle. To add or delete a remote control, you must access the RS3000 ECU (computer), location varies by vehicle and model.
To program (add) a remote control to the system:
1: Insert the key into the ignition switch and turn it to on.
2: Press and hold the ECU's programming switch for 3 seconds. The status monitors LED turns on for 5 seconds.
***You must perform the next step within 5 seconds***
3: Press and release a remote controls top or bottom button. Either button on your remote control can be programmed to operate the RS3000. The status monitors LED turns off. The piezo chirper chirps once. The exterior lights flash once.
4: Turn off the ignition. The ECU will now operate with the remote control just programmed.
Note: The factory preset operation is for the top button on both remote controls to operate your system; the bottom button is not programmed. To prevent accidental erasure of a remote controls code, we recommend that you program all your remote controls at the same time."
BUT, mine is still not working. tried everything but the right thing I guess. I don't have an additional system in there either.
