Me too.
I replaced my plugs, wires, distributor cap and rotor last weekend and also have the Check Engine Light coming on.
I am guessing I forgot to reconnect a vacuum hose. I will check this weekend.
BTW, I used an NGK Resistor Spark Plug Wire Set & plugs.
I also installed a new battery.
When I had the old battery out I removed the battery box and cleaned everything up under it. Sure hope I did not loosen something in there.
I recently replaced the plugs and wires. When i accelerate it does seem to go away. When stopped at a light (in drive) it idles and i get a very momentary drop in rpm which then returns to normal for a few seconds and then the cycle repeats. There is no way that i messed up the timing right? could it be something big wrong with the engine, misfiring?
