Rough start and idle when cold
College Station, TX
Hello all,
I’ve been having some issues on my 92’ 3fe.
A few weeks ago my rpms were surging to just over 2000 rpm at idle, as soon as I’d put it in gear or give it some throttle it would stall. I tested the continuity and resistance on all the sensors and relays associated with the efi system, and I found that my air flow meter was bad (resistance was out of spec when the measuring plate was both fully closed and anything other than closed). I got a new afm and replaced both intake hoses leading to the throttle body, I made sure all of the vacuum lines were in tact and connected properly. It’s been about a week and I haven’t had that problem again. However, It’s been rough to start when cold, 10-30 seconds of cranking before it fires up. Once it does start it idles rough, almost like a misfire, until it warms up. It starts fine at operating temp and the rough idle will last about 5-10 seconds then goes away. I have one diagnostic code (22) for the water temp sensor signal. I am currently waiting for the sensor to come in. Is it possible for a bad water temp sensor to cause these rough starts? Any ideas or suggestions would be greatly appreciated.
Thank you
New sensor is installed, it is starting much better. The cel is off upon cold start. After driving for about 20 min the light returns with the same code. The rough idle is still there
reset ecu?
Have you gone through the tests in the FSM on pages FI-37/FI-77?
