OBD 1 code 35 and idle at 2k
I will reiterate a previous statement.
If the TPS is not adjusted according to the FSM or is malfunctioning, none of this will work correctly.
The TPS is what "tells" the ECU that the throttle is in the idle position.
You've been super helpful and I really appreciate it. I'll test those this evening and report back. The reference you posted looks different than the FSM I have been reading from a previous post in this thread.
Taking this thread back to scratch. If I am trying to troubleshoot simply the DTC 35 I am getting as soon as the car is turned on, what steps might you recommend.
The snips I posted are from the Toyota EWD not the FSM. You should always reference both.
I'm at a loss to explain the 35 error code.
