- Thread starter
- #21
Well, following the advice of @flintknapper , I tested and confirmed that the car rolls in park in High range, but not when the center diff is locked in low range. So I had high hopes it was just a stripped drive flange.
So we put the beast on a lift at the mechanic's shop today. But when I pulled the front wheels, the drive splines look healthy to me (pics of the right side splines attached). So then I tried some of the other tests you guys described.
With all 4 wheels off the ground, shifter in Park, and center diff selector in High, I can spin either front wheel easily. When I turn either front wheel, the other front wheel doesn't turn at all but the front driveshaft does turn freely (the rear drive shaft stays still). Neither rear wheel can be turned at all (the parking brake is off). The rear driveshaft didn't move at any point during my testing of the 4 wheels.
Does all of that sound normal, or indicate a problem?
Tomorrow I'll have the mechanic open up the front diff to inspect the gears. If those are OK too, what do I check after that? The garage here would obviously like the root issue of all of this to have been the transmission problem they said it was from the beginning. So they are saying they want to adjust the shifter cable again. I basically have to lead them to the real problem here or they won't admit fault in an unnecessary tranny swap.
Please share any additional knowledge you have with me!
But if that was the case, and the center diff is not locked, wouldn't the rear drive shaft turn and both rear wheels turn?
