Builds rocks and rolls (3 Viewers)
cut down some tube I had from the original build
cut a 45 on the tube for a better weld surface
new import taps
lots of heat and scale build up
had to run the tap
had some design flaws in the steering
needed a longer pitman arm
new tie rod ends
the longer pitman arm hit the panhard bar
move the panhard bar
and the panhard bar hits the ram
it never ends
notched the panhard bar and sleeved it up
I really like that cover ...who made it and how much ? I will be needing this with winter on it's way..correction winter is here !!!:D
The cover has worked out great.
The cover has kept the morning dew off the dash and seats.
I had a local car upholstery guy make it.
The material is the same as outside awning fabric or marine fabric.
If I was to do it again I would sew it up myself...
I was able to pick up some material from a local Los Angeles vendor but the below link might get you started.
Sunbrella: Fabric showroom
realized I had the axle over to one side by a couple of inches
Tried to adjust it and the threads got nasty on me
attempted to machine the bung fitting out
welded a nut to twist off the bung
threads are all jacked up
finally machined the bung off and welded another one in
needed to finish up on the steering
of course that did not happen but I got a good start
got a remote resevoir
pushed radiator out of the way
pulled the pulley then the pump came off
Rather then hassle with a new can, I decided to modify the one I had
cut off the top
