Rochester with no Choke (1 Viewer)
Wyoming
I have rochester car dnon my 79 fj40. The PO that installed it changed it from the linkage to an accelerator cable. The carb has been working ok, but the choke was not hooked back up. Can the choke be hooked up on the new carb? I'd liek to replace with aisin eventually, but since its running fine, money goes to restoring the body instead. Its going to start getting cold here soon and the choke sure would help her get going in the morning.
If the rochester has a manual choke, I would think it would just be as simple as reconnecting the stock cable to the rochester, if its not long enough you may need to graft in some bicycle brake cable.
what if it is a divorced choke? Could I still rig it so that I can use the exisiting manual choke cable and hook it up somehow to the choke linkage? anyone ever done that?
also could you be more specific about grafting bike cable into the existing cable.... My manual choke cable is a couple inches shorter than I would need it to be....
Chaka
If the rochester is the same kit as the one ive got, the factory choke hooks right up. on the side of the carb toward the firewall, there should be a large plate with a hole in it for the choke cable housing to attach to. On the passenger side of the carb, there should be a attachment with a screw in it (similar in looks to the accelerator cable mounting point). This is where the cable attaches. Rochesters are a ridiculously simple carb, and as far as i know, were all manual choke for the fj40 kits sold.
mike
Hey there... thanks for your responses... I have a question though
For the carb.... the PO put a chevy 250 in my fj. Does what you are saying still apply? It does not have any choke of any sort on it. It does have the linkage, but no choke that I can find. I should be able to feed a cable in and make it manual, right?
have you done it before and do you have any advice?
Chaka
Post a picture of your carb? Is it a 1 barrel or 2?
The choke is either going to be a heat element style, heat tube, maunal, or electric. All depends on the carb, and what year engine it came of off. Need more info.
it is a 1bbl. ID 7040021 so it came off of a 1970. I have been told it is the divorced choke style....
I don't have a camera but will try and find a similar one on-line.
Dave
