So carnage from last weekend besides the dent....
My sliced sidewall with 6 plugs in it is not going to hold. I am bummed on this as it means a new tire is required. Although I suppose I could tube the tire, hate to do that though. Don't really want to spend well over $200 on a new tire when it is for a 15" rim that is to wide. I dislike not only the 15" rims but also that they are 10" wide. Any ways, not buying a new tire anytime real soon. So I put my 35x12.5x16 Maxxis Creepies on the truck. They are on some 16" steelie spoke rims that were supposed to be beadlocks. The guy doing the rims messed them up so we could not do beadlocks on them, as a result they just have a big "rock ring". They also need about 1" more backspacing. I checked another set of 16" steelies and they have to much backspacing! So I have a delima as I am out of rms to choose from but for now am just going to run the Creepies, just hate to do that because the rims suck and I do not want to run these tires on pavement much. Also the set up is not balanced but suprisingly I have little to no wobble.
One hub is not engaging. This hub was giving me problems and came apart while I was working on the front end. I thought I had it back together and in well but it seems not. Not only did this heavily limit me in the mud with only one front side locked it also means I need to tear the hub out again!
Exhaust is leaking pretty bad where the Y-pipe meets the single pipe. I told the shop last month when I had it fixed to weld it here. They didn't and now it leaks. Will try and get this welded up soon. Otherwise exhaust is all good. Didn't touch it with the front diff once while offroading and we were flexing the truck a lot.
I got Cruiser lean and I hate it! It seemed to be gone after the new suspension but then came back. It is odd because it will come and go. After this little 4wd trip it is super nasty and been leaning since. 2" lower on one side in the rear! If I had the cash I would just toss coils on this truck with a FF rear to boot! Alas I do not have the cash for those mods right now. So after like 4hrs reading on Mud about Cruiser lean and everyones opinion plus a variety of half-arsed fixes I decided what I want to do. I plan to buy a 2nd rear LHS OME HD leaf pack and put it on the RHS, I think I will end up with an A/A insted of A/B, need to check #'s. At least a couple people have done this here on Mud and the lean is gone for good. I am willing to give it a go for about $200 as I am fairly confident it will take care of the problem. Wish I knew about Cruiser lean before I got this truck! Most guys live with it but it really bothers me! After many years of working on Nissan Patrols I have never seen anything like this Cruiser lean!
Icon has been super slow to get the stabilzer out, I think I ordered it around the first week in September. Still don't have it....
I am working a lot so will not likely get have time do much to the truck until next month.
Got the exhaust leak welded up the other night. It is much better. Tried to clamp it down better, even put on a second new clamp but it still leaked. So we welded it up. Just means it gets the sawzall if it needs to come out!
Here is the Cruiser with the Creepies. I really like the skinny 7" wide rims. I also like the stance. The rims though really could use an extra inch of backspacing to protect the brakes, ect. For reference this is the exact same size tire as the MTRs just the MTRs are on a 10" wide rim with about 1" more backspacing. With a 10" wide rim it rubs on the back, sidewall to body inside fender. In the front it rubs at back of wheel arc at the bolts a tiny bit. In front at full lock it is very close to leaf springs. So I dislike the 10" wide rim not only for the looks but also due to these reasons. And yes I know the rims look like s*** and have surface rust!
