Can I reuse my front axle spindle that I knicked up with a dremel tool trying to get the brass bushing off for replacement ? (stock '83 FJ60)
The bushing looked kind of thin, so I tried taking it off 1st with a Harbor Freight 3-jaw pilot bearing tool to no success and then took a combination of a Demel tool cutting wheel, some WD40 and a brass punch to eventually knock it out.
Unfortunately there are cut knicks from the dremel tool at the outer side of the spindle where the new brass bushing goes. Since the new bushing is going to be pressed in (as opposed to screwed on some sort of threads), do these cuts matter ? Should I get a new spindle instead ?
Also, at the other end of the spindle there is a very slight "rifiling" from one of the brass puch motions I did inadvertently.
Can I reuse this spindle ? Am I being a "hypochondriac" or are these issues to be considered grave concerns ?
Thanks in advance for your time.
