Just wondering, if you boil new rubber in a Viagra solution will it make it hard ?
Great to hear about your good results. I discovered the same thing, old Honda motor cycle guys use it on their carb bases. I am soon to be doing this to an entire trucks worth of rubber. Hate to break it to ya but you paid way to much for the wintergreen oil. I also discovered from the Honda guys that go-cart racers use the stuff on their tires before racing, 100% wintergreen that is. So I found a go-cart supply shop that sells it dirt cheap. See for yourself. http://www.topnotchspeedshop.com/product/thor-oil-tire-prep-12-wintergreen BTW, wintergreen oil is toxic. Where rubber gloves and don't get it on your skin. Also you must be careful how long you treat the rubber part. To long and it will swell up 3-4x original size. Although I have read it shrinks back down over time. There is a number of methods but it seems the simmer in water is the best. For plastic, use peanut oil to restore it.Seems more useful to guys with older Cruisers where you can't get the rubber anymore. Cheers
Thanks - I'll make sure they're rubber and not some kind of soft plastic. I may try this on the worst of six, I know one has a small crack, so to me it's expendable.Just a heads up. If the part you are trying to soften isn't rubber, there is a good chance that the wintergreen oil will do some funky stuff to it.
I had bad results with the front fender vent gaskets. The process destroyed them, and they had to be replaced.
So far it's holding up. But the '86 has been out of the sun for almost a year now, taking up garage space usually occupied by my wife's Malibu. So it's only seen about a half year of daylight since I fixed the vent gaskets.Any update @4Cruisers on your rubber?
