Replace transmission fluid or no? (3 Viewers)
Arkansas
I’ve got a new to me 2012 that has an excellent service history but no known history of a transmission flush or drain and fill.
Currently sitting at 150k miles and transmission seems to be operating perfectly fine.
Is it worth the risk to even mess with the fluid at this point?
YES!
With all due respect, there's been quite a bit of discussion on this. Have you searched?
Yeah, I think the manual says you don't ever need to, but most of us have (I personally have), especially if you're hauling a trailer, huge tires or a lot of weight.
There's a theory that a high mileage transmission with worn clutches may be working ok because the old fluid in it has a lot of crap in it which increases friction. Replacing the fluid gets rid of the crap and then the clutches slip. I think there's at least one person here who had a trans fail after a high mileage oil change.
I think I'd try to pull some fluid out of the trans with a syringe and hose in the fill hole, and examine it. If it's not too dirty then its safe to replace the fluid. Maybe an oil analysis would be useful to know what too dirty is.
I suspect that if the only thing making the trans work is dirty fluid, it's days are already numbered, especially with modern transmissions with a ton of solenoids and valves. But that might be 10k more miles.
You nailed my concerns perfectly.
Thanks for that suggestion. Think I will do that first and go from there.
In my opinion, judging that the fluid is so full of clutch material that it may cause a transmission failure is always going to be subjective. The fluid in my A750F was pretty dark when I changed it, but it's been perfect since the change (nearly 30K miles). With a Blackstone oil analysis, it might tell you the fluid is fine, or that it is cooked, but it won't be able to tell you if it is cooked and that changing it will cause the transmission to fail. And, if you were to keep driving on the cooked fluid as indicated by Blackstone and/or a visual inspection, wear would definitely be accelerated relative to fresh fluid. If the transmission was otherwise fine, this could lead to a replacement much sooner than if the fluid had been changed.
My recommendation is to just change the fluid. If the trans were to be so far gone that the fluid change would push it to failure, at least it would fail now and not at some undetermined time in the future when you are enjoying your GX in the middle of nowhere. When you do change the fluid, it's worthwhile to drop the pan, clean out the magnets and any gunk, replace the filter, and do a full fluid exchange where all ~16 quarts are replaced.
Great advice.
This is more what I was thinking prior to making this thread. Thank you
Not that it would be a direct comparison but I was having issues with my 2009 scion tc. The car would shudder when I was stopped. I changed the transmission fluid and now it runs super smooth. The car had 230,000 miles on it when I changed it and most of those were in city driving. I doubt the previous owner ever changed or checked the trans fluid. I’ve also heard that the issue with changing fluid in higher mileage vehicles would be problematic for older vehicles.
I would do a simple drain and fill. That will change out 3-4 quarts and gently introduce new fluid, avoiding a shock to the system. Repeat later as necessary.
So I am thinking about going for it, and draining and replacing the fluid myself, so I stumbled on this video ...
My concern is that the pump he shows has a lot of line, and I have never used one before. How do you make sure all the fluid is out of the line, otherwise you could come up pretty short on fluid couldn't you? Or can you just keep pumping and it will clear the line of fluid all the way?
The easiest way to change that fluid is to find a shop that has a transmission fluid exchange machine (BG being a popular brand). That machine uses your transmission to pump the fluid and doesn't pressure the system. Don't let them upsell you any additives, cleaners, etc. Just find someone that has the fluid that you want to use and/or will let you supply the fluid. FWIW I have had great luck with Amsoil Universal ATF in my 80 series transmission. I changed the fluid first time around 125k miles and the original fluid was pretty dark. Changed it again at ~260k and the Amsoil ATF looked brand new. In fact it was hard to tell the used from the new.
That service, without fluid, normally runs around $100 but it's quick and you don't have to deal with anything.
You can do a DIY exchange using the transmission cooler lines that go into the radiator or the external cooler (if you have one). A much abbreviated version of this method, that I used on my GX470, includes:
1. Drop the pan, clean out gunk from the bottom, and replace the filter/gasket. Fill the pan with fresh fluid.
2. Disconnect the out line (from cooler to trans, at the cooler) and route it into a container with volume markings (cheapo plastic pitcher works great). You will probably need a hose barb and some 3/8 clear hose to extend it.
3. Have someone start the GX and run the shifted thru the gears, until it pumps ~2 quarts of dirty fluid into your pitcher.
4. Add 2 quarts of fresh fluid into the transmission. When I did this I added it to the unplugged return line, but it was super slow. Filling into the plug at the back of the transmission via a transfer pump would be quicker but requires you to crawl under the GX multiple times.
5. Keep repatting until you exchange all of the fluid and get clean fluid coming into your pitcher.
6. Start the GX, let the trans get to operating temp, and check the level via the level plug on the pan (FSM procedure). Either let the excess drain out or add more.
This method takes 2-3 hours and $100-120 total, if you use MaxLife ATF (synthetic Toyota WS replacement that is around $20/gallon at WalMart). It's a messy job but really easy and pretty non-technical. It does take 2 people.
Do you know of a youtube video that shows this method?
I found one for a 470 when i did mine but not specifically a 460. Presumably they should be similar.
You still need to use the FSM procedure for checking the fluid level at the very end.
Absolutely yes you should.
It is a crazy easy process.
With a 2" lift and 32s I do not need to jack up my GX.
Anyone sharing these in a specific thread? I changed my trans fluid at 114,000 miles for the first time and thought I would share. No problems before or after - feels like smoother gear changes now but could be in my head.
This is what I was looking for - I have the AMS - AMSOIL Signature Series Fuel-Efficient 100% Synthetic Automatic Transmission Fluid and about 120K and was going to replace it today.
Do it. At least do a drain and fill.
This is the way.
This is the way.
I don't agree with the CCN and what he is saying does not match my experience at all. IMO the "don't change all of your transmission fluid" is an old wife's tale. I certainly like many of the CCN videos, but he catastrophizes on fluids, non-OEM parts, and other weird stuff like transmission fluid changes. You'll also notice he's providing no evidence of his claims (i.e., "I did X and Y happens"). If he is going to make absolutist claims "Don't change the fluid", he needs to provide actual evidence.
I agree. Let me add, though:
The evidence is the drain and fill is dirtier = "worse." Hard to argue that. Any oil analysis will show the drain and fill has dirtier oil due to the volume/ratio of new oil difference. You would have to test it X0K later and then use some "math" to figure out if the change in "dirtiness" has been lessoned or something confusing and probably questionable.
To get evidence for a drain and fill being better, you would have to have a method of collecting data on failure rate of transmissions with drain/fill vs the flush method for a long period of time. Sounds tough to do. Maybe Toyota has done it.
The only evidence I have is my 2001 4Runner transmission w/ 120K miles started making a whining noise in 3rd gear after doing a flush. Took into Olathe Transmission as well as an offroad mechanic in Paola KS (now retired) and both said the flush was "bad" for the same reasons CCN stated. Shifted fine, not a big deal, but have never had a transmission issue or failure with drain/fill.
